Perdana v6 : Road to 300whp.... and beyond
sweelt
Nov 6, 2016
2,306
248
663
Penang
after few studies on other forum on piggy vs re-chip/chipped/reflash vs standalone, ill take re-chip for now. Engine with stock internal and @ 1bar boost, rechip should suffice. See dyno result and plan for 2nd stage.
Links evo+ for evo3 looks soo goood.
still able to run the car right? driving NA :nurse:
i read many vs vs vs...reflash is best alternative.
stock ecu "sometimes" outsmart piggyback. :smokin:
standalone, no boundary....lol
marsha1l_v6
666
130
543
IMO, standalone if you're going race mode 24/7..with no stock component hahaha..
would go that route if able to plonk this 4g63t to other awd.
Mine can add chip, got 2 empty space for it.....:driver:
so total 3 space? able to switch those chip slot on the go? :hmmmm:
Nope, 2 slots only. As far as I know VR4 have 3 variants. 200bhp cyclone, 220bhp and 240bhp RS. Mine is the 200 cyclone. Original ECU konk, this one no additional slots ECU. Manage to source for 220bhp ECU with slots, these 2 ECU can interchange and use. 240 one I heard cannot use in my 200 ride.
The chips are soldered on and programmed but I did not do it.....
egb18c
922
94
kuantan
I remember talking to a guy at Tong turbo, if I need to rebuild by turbo he can also fit double fin for me.....:smokin:
Hi sir or anyone,
Sorry to interrupt your conversation, but what do you mean by fitting double fin? 6+6, 7+7? Currently iam running blitz k3-450r, quite laggy, 4.7krpm full boost, old style turbo. Maybe like td06-20g range but bigger fin.
So my questions is, with double blade, will it give more power or better spool? if yes, which one configuration should i use? as there are mane double fin configuration, 6+6, 7+7 and so on. What ive manage to google is between garrett gt and gtx, the gtx uses 11 blade solid design, it gives better power with slower spool maybe 200-300rpm slower.
Regards
marsha1l_v6
666
130
543
abang2 ni semua turbo besar..
saya TD04 tumpang lalu.....
silakan lalu otai..
good to know, thanks for sharing. But that ecu does not have switch to toggle between the ECU?
Hi sir or anyone,
Regards
Hi,
iinm single vs double fin would be difference in efficiency(more air), given that single and double fin has same turbine/compressor size. But double fin may require better IC due to heat its produce.
reference : http://www.zerotohundred.com/newforums/showthread.php?t=268828
hope it helps :smokin:
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
Hi sir or anyone,
Regards
6+6 design cast wheel for better spool....
i would recommend 11 blade cnc wheel if u were upgrading from smaller/stock turbo.....
egb18c
922
94
kuantan
I dont know how to use multi-quote, but may thanks for the input sirs.
marsha1l_v6
^pomen_GTR^
Regards
pac_jb
131
14
518
Hi bro, I just installed piggyback and dynoed few months back, perdana evo 3 too, tuned and dynoed by MAG , currently I'm standing at 275whp with 313nm torque on dyno dynamics (306whp on dynojet) this is my spec:
Evo 3 with stock internals (top overhaul done last year)
Banana
Waste gate
Td05 16g boosting at 1.1bar
AVS piggyback
Engine Balancing shaft removed
AVS 255lph fuel pump
Works fuel regulator stage 1
Straight 3" exhaust from front to back
Works boost controller
Exedy organic clutch ( need to upgrade)
S90 70mm throttlebody with ported intake manifold
kurt_629
872
54
528
johor
Banana
Waste gate
AVS piggyback
always envy those with TD05 16g that can boost 1.1 bar, I only 0.8 despite bigger turbo..
no piggyback..
no boost controller..
everything stock..
fast car you got there.. Fat wallet too
pac_jb
131
14
518
Not fat wallet bro, it took me more then two years to do one by one with all the maintenance as well alot parts needed replacement due to the mileage
hey zth member, need your advise here. well, i just change my proton steering to the momo one and bought the hkd bosskit. and then hor... very hard wor.. like non power steering already. :( what happened? help me please. thanks.
