NEO wheel HELP
wiemsical
Nov 7, 2013
6
hy everyone.. please help. i am planning to buy the new proton neo 2013 . i was wondering , what pcd and offset for the new neo? thanks to those who reply
Get the car and go to tyre shop for fitting or are you getting rims from elsewhere?
wiemsical
6
yup, getting new sport rims from local shop
---------- Post added at 08:53 PM ---------- 6 hour anti-bump limit - Previous post was at 05:11 PM ----------
so , if i want to buy new rims.. is it important to tell the offset? and if its important.. i should buy rim with the same original offset?
---------- Post added at 08:54 PM ---------- 6 hour anti-bump limit - Previous post was at 08:53 PM ----------
yup , gonna buy new sport rims from local shop
slipar
500
61
banting - pj
tyre shop rim usually offset different from original..
if offset not right they will suggest spacer..
Original rim offset always further in. Tyre OE also narrower.
After market rims offset normally comes out further. They will have a few specs for you to choose. The smaller the number the further out it comes, therefore if original is +46, then go for +40 or max +38. +35 normally you will have problem scrubbing the rear wheel fender but these specification differs from car to car. Best to test out at tyre shop the various rims and even tyres if you are getting much wider ones...:driver:
chester91
18
503
I'm running the r3 15 rims which have offset +35. Tires 195/50/15. Lowered to 1 finger gap all around using adjustables. Tires Nvr sangkut fenders even with 4 ppl in the car n taking corner. But my car always scrape at car park rams n small bumps..
wiemsical
6
will run on 17 inch
---------- Post added at 02:52 AM ---------- 6 hour anti-bump limit - Previous post was at 02:51 AM ----------
ET +35 will surely look good
Will barely clear the rear dust cover and the front calipers ( if u running on 15inch )
will run 0n 17inch
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
neo use 17 sure looks good..but too heavy...
unless u were running on mivec final drive...
does anyone here have pics of those plastic water pipe air filters?
i know how to do it but i just need a picture as reference just in case i do it wrongly..
all i need is just to see how to hold it in one place as in how to do the bracket part..thanks
