Need advice on brake servo...
me2kimi
717
276
1,563
Puchong
Hi,
Dear all bro and sifu,
I need to change my brake servo for my ae111 ride. It's 4afe standard but with rear brake disk. This problem already happened when I'm still using rear drum brake and now even worse with rear disk brake.
Right now I have to press my brake pedal deep down so that i can feel my car is braking. last time i've adjust brake pedal lever to make it lower but braking really bad. Now the brake pedal is higher than fuel and clutch pedal, make me feel very hard to press brake pedal.
I've notice that the pedal have to move long distance so that it will press my brake pad. I think want to change brake servo. Can you all advice which brake servo should i used. And what different with single layer and double layer?
Thanks a lot.
TRD.AE92
780
40
Single layer mean 1 Layer of servo, double layer mean 2 layer of servo
I think better to have double layer brake servo. If your car got ABS, then the double layer may not able to be use with ABS system.
me2kimi
717
276
1,563
Puchong
nope, my car got no abs. from which model of car should i buy the brake servo?
thanks..
TRD.AE92
780
40
Double layer from AE111, AE101, Camry, or even Celica... All will be PNP only...
me2kimi
717
276
1,563
Puchong
orait, thanks bro trdae92
Dear sifus and otai
Need some advise here,my ride is proton persona 1.6 auto,is it recomended to change to open port air filter?currently i am using drop in air filter.What is the pros & cons on this?,also is it worth and recomended to add e-manage if my ride is standard and just changed the exhaust system only?your comment is highly appreciated :burnout:
