MSI 845E Max (MS-6566E Ver 2) HT Ready
All Other Stuff
al0n9
104
KL/Seremban
MSI 845E Max (MS-6566E Ver 2) HT Ready mainboard...
MSI 845E Max (MS-6566E Ver 2) HT Ready driver
-MSI 845E Max (MS-6566E Ver 2) HT Ready-product
CPU
• Supports Intel® Pentium® 4 processor in 478 pin package
• Supports 1.4 ~ 3.06GHz and up
Chipset
• Intel® 845E Chipset
- Support 400/533 MHz Intel®NetBurst micro-architecture bus
- Support AGP 4x slot (1.5V only)
- Support 100/133MHz FSB
• Intel® ICH4 Chipset
- 2 full IDE channels, up to ATA 100
- AC'97 Controller Integrated
- Low pin count interface for SIO
FSB
- Support 400/533MHz Intel NetBurst micro-architecture bus
Main Memory
• Support max. of 2 double-sided DIMMs with unbuffered DDR 200/266
• The largest memory capacity possible is 2GB
• No support ECC Function.
Slots
• One AGP (Accelerated Graphics Port) 4x slot (1.5V only)
• Six PCI 2.2v 32-bit Master PCI bus slots
On-Board IDE
• An IDE controller on the ICH4 chipset provides IDE HDD/CD-ROM with PIO, Bus Master and
Ultra DMA66/100 operation modes
• Can connect up to four IDE devices.
Audio
• ICH4 chip integrated
- AC'97 codec supports Realtek ALC650 6-channel audio
LAN
• ICH4 chipset Onboard Intel LAN
- ICH4 + 82562ET Integrated
On-Board Peripherals
• On-Board Peripherals include:
- 1 floppy port supports 2 FDD with 360K, 720K, 1.2M, 1.44M and 2.88Mbytes
- 2 serial ports (COM A + COM B )
- 1 parallel port supports SPP/EPP/ECP mode
- 6 ports USB 2.0 (Rear x 2 / Front x 4)
- 1 Line-In/Line-Out/Mic-In/Game port
BIOS
• The mainboard BIOS provides "Plug & Play" function which detects the peripherals devices
and expansion cards of the board automatically
• The mainboard provides a Desktop Management Interface (DMI) function which records
your mainboard specifications
Dimension
• 30.5 cm(L) x 20.0 cm(W) ATX Form Factor
Mounting
• 6 mounting holes.
*item sold
tq
interested?
call me : 012-333 9730
al0n9
104
KL/Seremban
no warranty bro.. but this mobo still working well, cond is good..
used for 2 years already..
al0n9
104
KL/Seremban
over,please delete some of ur pm bro'.. i can't rep your pm..tq
I just bought an evo 3 throttle body. The seller said that it would fit into wira 1.6 and same goes to Perdana sei.
Perdana sei is my car. Currently im using jasma 72mm throttle body which in the end have its sensor broken and i tried installing evo 3 throttle body but the timing/rpm went bursting everytime i start the car, and i'll quickly turn off the engine. And now i've cabut it back.
so... CAN REALLY EVO 3 TROTTLE BODY FITS PERDANA SEI STANDARD ENGINE?
if can, do i need some...
