LS-H31888 Degree Wheel
Car Culture
jaspersoong
70
- It can be used to adjust the tension on the cambelt where the movement of timing belt is measured by load (NM).
- Suitable for use on cam belts various belt widths.
- Clear incrementa marking with kurnled knob for precise measurement.
- Dual scale allows reading from top of bottom of tool.
The windscreen water spray on the bonet .. the right one is working but the left one having difficulties spraying the water out. What are the things should I check? :unsure:
