Looking for nissan skyline gtr34 around rm 160k
[PIMPIN]
2,138
648
3,213
to answer your question, i'll pass it to temujin or pimpin or v-spec to answer it.:biggrin:
all the skylinExpert :adore:
Among the diff. ways to tell (from other forums):
V-Spec over Standard GT-R has
* front splitter and diffuser
* rear carbon diffuser
* lower stiffer suspension
* exhaust temp and intake temp sensors shown on MFD
* ATTESA E-TS Pro + active LSD at rear
V-Spec II over V-Spec has
* aluminium pedals
* brake upgrade on rear
* carbon bonnet with naca duct
* slightly darker iridium console
* black door trim and seats with white stitching
* more stiff suspension
* clear front indicators
bikerz
213
by the picture, does the front and rear diffuser is v spec?
[PIMPIN]
2,138
648
3,213
I'm going to go with yes despite probably the world's worst pictures of the exterior. If you're in doubt, look at the MFD with engine running with the type of display showing all sensors (which should include egt and intake temp unless its a Nismo dash already) and another of the dash with the key in ignition and in the on position but not yet started (with all the lights on the dash lighted up - there should be A-LSD light).
Some will advice you that its easier for you to take a picture of the VIN plate to look up but the above tips or meant for those out inspecting a GTR in person and do not have immediate access to Internet and/or friends to call.
Additionally, if the car is a 2000 model then it should be a V-Spec. I believe the non-Vspec GTRs were available initially during the launch in '99 prior to the V-Spec being introduced later that same year and the V-Spec II in following years. I'm not 100% sure if non-Vspec GTRs were available throughout the models lifespan ('99 to '02) but I doubt they were. However, I'm sure someone on here knows for certain and can confirm whether or not that's true.
V-Spec
1,861
170
5,163
Anyone wants an ER34? Hehe
V-Spec
1,861
170
5,163
raulisfadzil, if the price is right. :)
the passanger side of my headlamp broken, so change a new OEM one
after install u can see the difference of new and old. the driver side
is a bit yellowish
any way to restore the glass headlamp to match back the new one?
thanks in advance.....
