Load Dyno Vs Inertia Dyno
jinkl
4,624
376
3,183
This discussion revolves around chassis dynamometer's and is intended to be informative and thought provoking. There are two types of chassis dynamometers on the market, inertia and loading. An inertia dynamometer (such as DynoJet) does not measure torque, but measures acceleration. A loading dynamometer applies resistance that is measured (using some type of strain gauge.)
The most often heard discussion is that what factor can be applied to rear wheel horsepower to reflect crankshaft horsepower. This is where we need to understand how the rear wheel horsepower number was derived. Since the DynoJet seems to be widely used and numbers quoted are those from a DynoJet, we are going to use them as our inertia dynamometer example.
First it is important to have an understanding of how DynoJet gets their horsepower numbers. Power in mechanical terms is the ability to accomplish a specified amount of work in a given amount of time. By definition, one horsepower is equal to applying a 550 pound force through a distance of 1 foot in one second. In real terms, it would take 1 HP to raise a 550 pound weight up 1 foot in 1 second. So to measure horsepower, we need to know force (in pounds) and velocity (in feet per second). Dynojet's inertial dynamometer measures power according to the terms just described. It measures velocity directly by measuring the time it takes to rotate two heavy steel drums one turn. It measures force at the surface of the drum by indirectly measuring it's acceleration. Acceleration is simply the difference in velocity at the surface of the drums from one revolution to the next. The force applied to the drums is calculated from acceleration using Newton's 2nd law, Force = Mass * Acceleration. Since the mass of the drums is know and acceleration has been measured, Power (horsepower) can now be calculated. Torque is then calculated using the horsepower number: Torque = Horsepower * 5252 / RPM.
Once they have these numbers a series of correction factors are applied, some made public, some hidden as proprietary secrets. The public correction factor is the SAE correction factor. This formula assumes a mechanical efficiency of 85%. The formula used is: Where: CF= 1.18 * (29.22/Bdo) * ((Square Root(To+460)/537)) – 0.18. To = Intake air temperature in degrees F, Bdo = Dry ambient absolute barometric pressure. This correction factor is meant to predict output in varying atmospheric conditions and is a +/- 7%. The proprietary correction factor is supposed to reflect the loss of power from the crankshaft to the rear wheels.
A Loading Dynamometer applies resistance to the dyne's roller(s) , typically using either a water brake or a current eddy brake. In either case, the amount of force is measure using a strain gauge. The measured force is torque which is a real, indisputable measurement of the actual output at the wheel. Horsepower than can be calculated: Hp = Trq * 5252 / RPM.
A Dynamometer can only measure actual power at the output location. Actual power produced AND delivered by an engine will be highest if measured at the crankshaft, lower at the transmission output shaft and even lower, but more meaningful, still, at the rear wheels. The power that you use is the power at the rear wheels. Some Dynamometer companies add to measured rear wheel power readings a factor that is based on ESTIMATED rear wheel power losses (under what power conditions? 3.0 ltr.? 5.0 ltr.? Under coasting conditions? with a 185/70/15 radial tire? a 335/35/18 radial tire? New heavy radial tire vs. worn old, light, racing tire? Who knows?) In short, there is NO meaningful "average" tire to get a correct rear tire power transmission loss measurement for all cars - so obviously, unless they actually measure the power lost in the rear tires, under driven load conditions, NO dyno company should BE ADDING incorrect power figures into the measured power. It's simply wrong. The fact that they add varying amounts of power to the actual, "true" amount of power delivered and measured to the surface of the drive roller creates a situation that makes it an onerous task to compare power figures from different brands of dynamometer systems. On simple inertial dynamometers, some (most) companies use an average for the inertial mass value of the engine, transmission, driveshaft, axles and rear wheels. This is saying that a 4 cylinder, 2.0 ltr. Porsche 914 has the same rotating mass and same rear wheels as a 8 cylinder, 5.0 ltr. Porsche 928 S+4. This simply is not so and wrong.
It's expensive to measure frictional losses in the engine and drivetrain, requiring the dyno to be able to drive the vehicle with engine off. Add the cost of a 50+hp electric motor, controlled power supply, etc. It's just not likely that $20,000 dyno will be equipped with that equipment. It is also common for dynamometer companies to add to the power readings by adding transmission and driveshaft losses back into the measured power readings. Some companies make a concerted effort try to measure frictional losses and, optionally, add the power to the measured readings. Other companies - some that would surprise you - say that it's not important and give a blanket, single factor for frictional losses in every engine. Some simply say that there is a meaningful "average" for every car,( 4 stroke/ 4 cylinder/ 4 speed transmission, 4 stroke/ 8 cylinder/ automatic transmission) and apply it to every car and that it is not a significant difference. Blanket estimates of "average" losses and corrections are, quite simply, incorrect. At the upper levels of the industry, (we are talking about $150,000 - $500,000 AC or DC 4 quadrant dynamometers) it is not tolerated - shouldn't be - and needn't be. There is a dyno company that actually has different versions of software that displays their own identical data files as different amounts of power depending on whether you use the DOS version or the Windows version of their software!!
True, rear wheel horsepower is the standard of measuring the power that is actually delivered to the rear wheels. It is honest, true, fair and duplicable. It is the ONLY standard that can be duplicated by the entire industry - regardless of the dyno manufacturer. From my experience and that of many others, when comparing True, rear wheel horsepower to DJHP you must apply a factor. It appears that this is a sliding scale based on horsepower but the best estimate is 1.05 to 1.21 (maybe higher). What this means is that for those of you trying to calculate what your crankshaft horsepower is based on DJHP, and are adding 15%, the most common number I hear, you are actually doubling (at least) the factor. Why? Because DJHP already has a puff number added into their DJHP. Lets say DJHP shows 200 hp and you add 15%, you get 230 hp crankshaft horsepower. In reality DJ has already added in 15 or 20% to their 200 DJHP number. How does this help us.? It does not, and is fact harmful to the many dynamometer test facilities that report only what the dyno actually measured. I can not tell you of the many discussions that we have had as to why the horsepower numbers we recorded lower than that of DJ. For those manufacturers that use DJHP as proof of their claims, can you imagine the shock your customers get when the horsepower number of a vehicle tested on a load bearing dyno do not come close to their claim.
Proper tuning, especially on highly modified engines greatly affect the power difference. Due to the fact that the DJ dyno's sweep so quickly on sweep hp tests, there is no way to properly tune a fuel map. What you get is the acceleration and full throttle maps both triggered during the test, ending up over-rich, affecting the horsepower. The other factor that needs to be taken into account is that DJ dynos assume that every vehicle has the same rotating mass - they don't - and that disregard is another reason why the hp conversion figures are different. The most accurate measurement of rear wheel horsepower is in Steady State Mode (inertia is not a factor in power equation.) The inertial mass changes on each car affects the DJ power, but not the true, rear wheel horsepower. There's another message in the above example, besides the average true, rear wheel horsepower to DJHP conversion factor - It's up to the more experienced reader to figure it out.
Chassis dyne HP, What is it? What to call it? DynoJet = "DJHP". It's not really proper to call "DJHP" "rwhp", as neither the Mustang, DynoJet, Fuchs, Superflow or Land and Sea will necessarily produce the same numbers as a DJ dyno, except by luck - and the whole idea of true, rear wheel horsepower is that EVERY dyno manufacturer HAS the capability to provide those numbers! The Superflow chassis dynes, the Mustang, Land and Sea are all capable of measuring power in steady state mode and producing the same numbers - they all measure torque. Torque x rpm / 5252 = horsepower. We've not diddled with physics! The only factor that is added to the measured reading, in true, rear wheel horsepower, is the additional energy (dyne parasitics) required to spin the dyno(s) roller to whatever speed the roller is turning at - logical, proper and required for any measuring instrument, torque x rpm / 5252 = horsepower + parasitic power = true, rear wheel horsepower.
Chassis dyne HP, What can inflate HP readings on a dyno, but not really make more engine power in the real world? A few things can affect HP when using inertia dynos (not a dyne in Steady State Mode) to measure power (what else would you do??:-): Changing to light, worn race rear tires will improve power output on an inertia dyno, but, not improve real world top speed. A heavier (brand new street) tire that replaced the above, light, worn tire, will decrease measured power on an inertia dyno, but not decrease real world top speed. Lighter wheels are a good thing! Better acceleration in lower gears, especially 1st and 2nd (accelerating less inertial mass!). Better handling is possible, too! Driving hard on worn, light tires is foolish and is not being recommended.
Problems with Inertia dyno test procedure and fuel injected vehicles: A Sweep Test (hold throttle wide open and sweep from low rpm to high rpm) will often trigger the Acceleration Fuel Map, along with the Main Fuel Map, causing the fuel mixture readings to indicate dyno operator that the motor is overly rich. This would cause the tuner to lean out the main fuel map. Of course, in the real world, upper gears, the acceleration rate of the engine is much slower than what they tested, doesn't trigger the Acceleration Fuel Map, and the engine ends up a lot leaner in reality in top gear. It's not that common of a problem, since most people never drive that fast for that long to cause engine damage. Work around: Tune full throttle fueling in real world usage at dragstrip (to best trap speed) or in Steady State Mode on different dyno.
You can optimize tuning for a DJ dyno and make big numbers - and you can tune the engine to make the best power under load on a load bearing dyno and blow off the big DJ dyno numbers. Can a tuner cheat and make a load bearing dyno read higher? The only way that could happen is in a Sweep Test - Sweep Tests are the least reliable of all tests, period. There is NO question about that. Since the Rotating Mass is a variable in a Sweep Test (NOT a Steady State Test!), the actual inertia factor entered affects the final HP figure - Tell the software that the vehicle has a lot of rotating mass to accelerate, and the HP number increases. (torque, rpm, acceleration rate and mass are the factors) - just like DJ dyno ignoring the difference in mass of all cars - So - true HP, again - Steady State Test - No acceleration, mass makes no difference, anymore. Torque, RPM and dyne parasitics. Period. True. Can you make a Steady State Test read higher? Really hard to do - The software will NOT take data unless speed and load are completely stable - eliminating cheating. As far as atmospheric conditions making a +/- 10% difference? Unless you REALLY mess with the barometric pressure (and you can look at every atmospheric factor on the test report sheet - it's hard coded to display - and not an option), it is simply, absolutely impossible to do without obvious evidence. Are final tuning optimal dyno settings different on an Inertia dyno vs. a load bearing dyno? For many reasons, final tune settings are different - and, since most load bearing dyno's will do both , there is a choice of tests - from a DJ style Sweep Test to Steady State. Having a choice of those types of tests to do and seeing what the results on the track are, most tuners will choose the Steady State Test over a Sweep Test. Without a doubt - the Steady State test Mode is the most consistently superior method of tuning - anybody who has the capability to do it will echo that sentiment - it's only an arguable point with those who can't do it properly. One of the reasons why the load bearing dyno will provide settings that work better in the real world is that combustion chamber temperatures are more in line with the actual operating temperatures that the engine.
Does altitude make any difference at all in horsepower? The engine couldn't give 2 hoots at what altitude it is tested at - it only cares what the air pressure, temperature and humidity is. Sea level at 28.02 inches baro is exactly the same as 4000 ft at 28.02 inches, as far as the engine is concerned. When tested at 5000 ft, we get virtually exactly the same power (corrected to atmospheric conditions, of course) as we do at sea level - It's just about 24%-25% less on the track! I am confused why some dyno operators insist on putting altitude on their charts and swear that it's a factor.
Crankshaft horsepower vs. true rear wheel horsepower. That's a tough one. As each vehicle is different, the best way is to dyno the engine and then dyno the vehicle to see exactly what the loss is. The best estimate I can give you based on experience and research is take crankshaft horsepower, subtract 14.5% ( search SAE ), take that, and subtract around 10% to 15% and you'll get about true horsepower at the rear wheels. The actual formula contains a curve for power loss through gears and there's another curve for power lost in a tire. Remember, too - that unless you dyno your engine you are only likely to get a crankshaft number from the manufacturer and that's probably a "good" one that the marketing department is providing.
jinkl
4,624
376
3,183
Quote:
<table border="0" cellpadding="5" cellspacing="0" width="100%"> <tbody><tr> <td class="alt2" style="border: 1px inset ;"> Mustang is a true measure of torque.
DynoJets read whp and use engine rpm to calculate torque. Teh dynojet has no way of simulating vehicle load at speed. When you get the rollers rolling, it takes no more hp from the car to keep it there. The Mustang Dyno had the ability to artificially load the rollers to simulate car weight at speed, more closely representative of what is take to keep a XXXXlb car moving at speed.
Both have correction factors but Mustang (or any load dyno) should give a better real world reading. Once you are tuned on a Mustang, there is little chance of it running leaner on the street then on the dyno like a DynoJet. Load dynos also run sweep tests in steady state mode which is a much slower and easier to read test. And they have more plot points and are a true measure of trq.
I asked the same questions and came to the conclusion that the Mustang was the way to go to tune to my 100 map fuel grid. If you're tuning an SAFC with 10 grid map it prob doesn't matter as much.
I was told on this board that the Mustang probably wasn't programmed properly by the authorized TEC, Motec, AEM and Hondata certified tech that owns the place and that is the difference in numbers.
I have searched teh net time again for Mustang vs DynoJet and have never found the DynoJet to read lower numbers. Try it.
Datalogging at the track is the only true measure. For tuning pick one and stick with it. </td> </tr> </tbody></table>
Inertia vs. loading dyno information
Here we come to very interesting collision about chassis inertia dyno versus chassis loading dyno. Simple question which type of dynamometers is better for tuning cars? Or maybe in what cases should be used inertia or loading? Is it possible to tune car at partial throttle using inertia dyno?
Before answering that question let's look at the main difference between an inertia dyno and a Dyno Dynamics eddy current dynamometer:
An inertia dyno has a very heavy roller(s) and a speed measurement system. The car is run at full throttle. The more power the car has the quicker it can accelerate the heavy roller. Knowing the inertia of the roller and the acceleration it's a simple calculation to obtain power.
A Dyno Dynamics eddy current dynamometer has very light weight rollers. It also has a speed measurement system. In addition the Dyno Dynamics has an electromagnetic retarder that apply a load to the rollers. This load is adjustable and it works at steady speed as well as when accelerating. The dyno operator (technician) can vary the load from almost zero to very large. Knowing the inertia of the rollers), the acceleration, and the load applied by the retarder it's a simple calculation to obtain power.
OK, so what are the main differences from the motorist point of view?
An inertia dyno cannot apply load unless the vehicle is accelerating. This makes it impossible to test a car on a level road at steady speed on flat roads or up hill, or slowing down due to hills etc.
A Dyno Dynamics dynamometer can easily test a car on a level road at steady speed on flat roads or up hill, or slowing down due to hills etc. A Dyno Dynamics dynamometer can easily hold the vehicle at a say 50% throttle and 2,500 RPM while investigating a misfire that occurs under these conditions.
Mapping the vehicles fuel and ignition computer is part of tuning any performance vehicle. How does an inertia dyno compare with an eddy current dyno?
In it simplest form, “mapping†a modern fuel injection computer involves:
• holding the engine at a particular RPM point (say 3,000 RPM)
• holding the throttle at a particular position (say 90% throttle)
• observe Air:Fuel ratio
• power
and adjusting fuel and timing to achieve best results. This process is repeated at a large number of RPM points and throttle openings. when mapping is complete, the engine will have optimum ignition timing and fuelling at all points in it's operating range from idle through to max power. When steady mapping is complete, mapping whilst accelerating can be performed.
Does this mean that mapping at full throttle is possible on an inertia dyno, but an eddy current dyno is required for mapping the entire engine range?
Mapping at wide open throttle is possible on an inertia dyno in a limited way. For example, lets consider full throttle testing two cars with the same 150 HP engine. One car weighs 2,000 kg, the second car weighs 3,000 kg. On the road the heavier car will accelerate much slower than the lighter car.
• On an inertia dyno both cars will accelerate at the same rate.
• On a Dyno Dynamics dynamometer the operator can choose the rate (or let the software calculate the rate).
The rate of acceleration affects not only the engines requirement for fuel etc, but also combustion chamber temperatures vary considerably with acceleration and time under load. These variances required different mapping values.
As for atmospheric engines it seems clear, but what about forced induction? Is it safe to tune forced induction car on chassis loading dyno? Another side, will inertia dyno create enough resistance for engine to fully boost and produce maximum power?
Accurate and repeatable dyno test results depend on accurately simulating conditions. With forced induction engines this is even more important. For example, a Dyno Dynamics dynamometer enables the operator to stabilize conditions prior to each graph test. If the engine is simply run to the desired starting speed, than given a foot full (sorry, wide open throttle suddenly applied), then conditions at the start of the test will vary and so test results will vary. Turbo lag is a very important factor when testing turbo engines. For accurate results the acceleration rate during graphing is critical. Inertia only dynos have no means of stabilization at the start, nor controlling acceleration during the test. </td> </tr> </tbody></table>
Quote:
<table border="0" cellpadding="5" cellspacing="0" width="100%"> <tbody><tr> <td class="alt2" style="border: 1px inset ;"> Dynamometers: interview with Dyno Dynamics owner Chris Hodges
Interview with Dyno Dynamics owner Chris Hodges.
<table align="right" border="0" cellpadding="0" cellspacing="0" width="1"><tbody><tr><td> </td><td>
</td></tr></tbody></table> First of all maybe you could say how does company Dyno Dynamics borne and began developing dynamometers?
Chris Hodges: My previous business Dynomotive was the leading workshop for quality work and accurate diagnosis in Melbourne, Victoria. At Dynomotive we used an eddy current dynamometer. It had some shortcomings but did a fair job. We could do things in five minutes that took five hours on the water brake and could never be done on an inertia dyno. People came from all over Victoria and interstate (even some from Perth over 3,000 km away in Western Australia) to get their cars (and trucks) “dyno tunedâ€. In Australia, water ski boats powered by big with five or six litre V8 engines are common. After experiencing the difference the “dyno†made to their cars, a lot of my customers wanted us to “dyno†their inboard boats as well. Well that was a problem. You can't fix what you can't test and diagnose! We couldn't even road test a boat without damaging the prop and scratching the road!! We needed a boat dyno!
How did you go about making a boat dyno?
With the help of my (now) business partner Peter Humphris (fitter, turner, toolmaker, mechanical genius), we made a crude dynamometer that connected to the propeller shaft. A friend, Alan Oxenbould (electronic genius) made the electronic control system. It sounds easy but it took us several years to get it working properly.
It turns out, that if you join a V8 inside the boat, to a big retarder outside the boat, via a couple of yards of thin (1â€) stainless steel shaft, give it a foot-full at five and a half grand, make it cough, without breaking anything or tying shafts in a knot, you have invented one hell-of-a dyno control system. We boat “dyno tuned†at night, and dyno tuned cars during the day. Because the boat dyno control system was so good, we decided to go into the dyno control system business.
Also how does it happened, that "Dyno Dynamics" in lot cases became a dyno standrat (company Dyno Dynamics in most cases is mentioned with a very big respect)?
I think that the main reason that Dyno Dynamics dynamometers have become the standard is because they have been designed by people who know how to use a dyno , rather than from the point of view of a design office. Peter, Alan and myself were very committed to making the best dynamometer in the world. In this we have been very successful. We have developed a very advanced yet simple design of roller chassis. The obvious things like roller design, vibration free beds, and hi traction roller surface have been designed to make the job of the dyno technician as easy and accurate as possible. The electronics we designed provide a very stable control systems, very steady readings and very high accuracy and repeatability.
• power
Accurate and repeatable dyno test results depend on accurately simulating conditions. With forced induction engines this is even more important. For example, a Dyno Dynamics dynamometer enables the operator to stabilise conditions prior to each graph test. If the engine is simply run to the desired starting speed, than given a foot full (sorry, wide open throttle suddenly applied), then conditions at the start of the test will vary and so test results will vary. Turbo lag is a very important factor when testing turbo engines. For accurate results the acceleration rate during graphing is critical. Inertia only dynos have no means of stabilisation at the start, nor controlling acceleration during the test.
I found what your company has established a "Code of practice", so you claim total honest between your tuning specialist and clients? Is this possible using dyno software to falsificate dyno run results and fool client?
It is possible to fool the client by many means. Even something as simple as using full throttle or nearly full throttle will affect results. Dyno Dynamics Shootout software rules out cheating with software; the Code of Practise and other things rule out other forms of cheating due to the operator lack of honesty. </td> </tr> </tbody></table>
Quote:
<table border="0" cellpadding="5" cellspacing="0" width="100%"> <tbody><tr> <td class="alt2" style="border: 1px inset ;"> Why our Dyno Dynamics dyno is better.<!-- google_ad_section_end --> <hr style="color: rgb(153, 153, 153);" size="1"> <!-- / icon and title --> <!-- message --> <!-- google_ad_section_start -->Why is a loading dyno (Dyno Dynamics) better than an inertia dyno (dynojet)? - Loading dynos are better than inertia dynos for a number of reasons.
A) Steady State Tuning - Steady state tuning is the highlight of the loading dyno. Because the loading dyno uses an electric brake to keep the rollers from accelerating it is able to precisely vary how much load is placed on the cars engine. When the dyno exerts as much load on the engine as the engine is putting out, the rollers will stop accelerating and hold a constant speed. Because the engine is not accelerating we call this a steady state. During this time the dyno is measuring the load between the brake and the car and outputs a live power number. This is very useful for tuners because it allows them to make changes to each part of the ignition/fuel map and monitor the power gains or losses in real time. With an inertia dyno there is no way to keep the rollers from accelerating and therefore no way to hold a steady state. The engine simply accelerates through the ignition/fuel maps too quickly.
B) More precise measurement - Because inertia dynos use a heavy mass to simulate the inertia of the car being tested it is hard to monitor minor changes in power. The large mass of the rollers results in very minor changes in roller speed that inertia dyno sensors have a hard time picking up. If the sensor and computer don't see the change in roller speed the the dyno graph will not show a dip in power. However, a loading dyno uses rollers with very little mass and directly measures power rather than calculating it. Quick drops in power will be picked up by the load sensor and will show on the dyno graph. This is very useful for finding problems and ensuring that your engine is running correctly.
C) Load can be controlled - With an inertia dyno the load exerted on the engine as it accelerates is based on the inertia of the dyno rollers. This inertia is set by the mass of the rollers and is not able to be changed. The inertia of the dyno rollers directly determines how fast the cars engine will accelerate through each gear. Ideally this inertia would be equal to the inertia of the car being tested but this is rarely the case. The inertia is almost always going to be higher or lower than the inertia of the car and as a result the engine accelerates faster or slower than it would on the street. This can have a bearing on how the engine is tuned and how accurate the dyno replicates real life conditions. Because a loading dyno is able to actively alter the load on the rollers it is able to change the rate of acceleration as the operator pleases. Realistic loads for the particular vehicle can be used or loads simulating driving up a hill can be used. This is easily controlled by the dyno operator.
D) Problem Diagnosis - This feature goes back to the ability to control load and do steady state tuning. A loading dyno is able to simulate road conditions in a safe environment while allowing the technician to monitor the car and it's engine. An inertia dyno is unable to accurately simulate all but a few road conditions making it much more difficult to diagnose problems.
these articles are from
http://www.perfengine.com/dynoinfo.htm
http://www.redline.lt/magazine/spec-.../article/16/1/
http://www.tamparacing.com/forums/el...no-better.html
EGNINE
513
65
3,028
jinkl,
can u list down load dyno machine brand available in malaysia...ive done my tuning on Dynojet and the result is the AFR become too lean ..but on the graph it looks ok
5115
Nobody
5,952
2,254
wow, nice copy and paste.
wonder whether the guy who posted this read everything or even understood anything.
we dun mind any copy & paste as long as it's a constructive thread.why care thread starter understood or not?
suicidebomber
Banned
Mar 8, 2009
13
ya but still,
nice copy and paste
jinkl
4,624
376
3,183
haha please la dude, you cant even diffrentiate a N/A and a turbo, lolx can go claiming a twin turbo waja, wht did you use , two house fans ? lolx
its stated above the source of the articles, dont be a jackass lolx
we sit on the dyno nearly everyday, we know whts being explained
i dont tink u even understand a single bit lolx
zamiex
443
11
nice info,
mustang dyno have ke at malaysia?
need to try la hehehe :rofl:
kuyeen
3,360
kl
very good info bro...:adore:
so any suggestion where is d best load dyno in KL/selangor
load dyno=dyno dynamics ?:confused:
Doink
3,492
14
House
actually you are very right !!! most people wont know it but thinking that a dyno-ed result power is the same power with that they will get on the road...that is so wrong...A lightweight 700hp car will over take a heavy 720hp car on the straight...its the power to weight ratio that is important.
too light a car with a powerful engine will get get unbalanced car.its all about BALANCE !!!
tigger5251
240
27
last week I just road tuned my car, and the results are as below:
Dynotuned on Dynojet GT Auto, 4 throttle position
- 127whp@6500rpm
- 160nm@3200rpm / 172nm@4500rpm
- AirFuelRatio 14:1
- RM10 Ron97 = 38km
- 100kmh in 8.29 seconds (according to dashboard meter)
Roadtune with A/F Meter (2 throttle position)
- 140whp@6800rpm (rectified when went dyno after roadtuned)
- 176nm@3000rpm / 188nm@5500rpm (rectified when went dyno after roadtuned)
- AirfuelRatio 13:1
- RM10 Ron97 = 35km
- 100kmh in 7 seconds (according to dashboard meter)
Proved that road tune is better than inertia/load dyno tune. No need argue here liao :P
jinkl
4,624
376
3,183
- 127whp@6500rpm
- AirFuelRatio 14:1
- RM10 Ron97 = 38km
- AirfuelRatio 13:1
- RM10 Ron97 = 35km
:) problem is when the HP is insane to be roadtuned :)
deacon
Senior master debater
1,167
30
I'm confused, so that means to say that 90% of the dynos in M'sia are inaccurate because they are Dynojet?
I've tried reading thru the articles posted but it seems that Dynojet produces a lousier product as compared with Dyno Dynamics...
Does anyone have a comparison read between for a stock car on both dynos on the same day? A bit much to ask but then what other way is there to measure what you are getting from the factory...
tigger5251
240
27
Perhaps, dynotune, is one way to know BEFORE/AFTER certain modification changes or different tuning done, to see whether improvements yielded or not.
And, every car characteristic is different. The weight, the traction, the engine respond. All these factor can only found out on-road tuning. Otherwise, we donot know how to make use the power, and how to tune the powerband to suit the car.
Also, not all the time 14:1 works all the time, sometimes 13:1, sometimes 12:1 (Im refering to N/A) This is what I can share :)
PS: All my sharing is based on my experience driving my car, and a close friend/tuner sharing his experience with me.
You canot say this dyno machine is lousy, that is better. My advise is, once you find a tuner who is reliable, trusthworthy (which is hard to find nowadays)....it doesnt matter what dyno they using. Just keep track of each changes/mods u dont to your engine, using the same dyno. The purpose is to know the improvement is there or not, and enable to tuner to tweak until desired results.
Final tuning, always done on road. And yield the best result. A simple drag test timing, and a few round the circuits, that is most important to know, how to harness the "improvement" done to the car.
Hints : Dont read articles, or listen to others' claiming. Experience everything yourself. Last time I thought B16A is a wonderful engine with 170bhp.....Turns out 120++whp only on a dyno....(zzzzzzz) Sometimes, experiencing the real thing, is a great revelation !
---------- Post added at 02:42 PM ---------- Previous post was at 02:33 PM ----------
Well, you're refering to monsters turbo engines with 300bhp and above....Am I right ? This case is different, I have to agree.
Ok, all this thing are nothing to do with me and I don't know him or her. Just helping him to spread the words.
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Kes Langgar lari...MYVI 1.3 ezi PUTIH plat WSH 1781 dicari...
Mintak Tolong pada warga CG semua!
adik pompuan kawan aku kena langgar lari ...cedera teruk...skrg di ICU...
kenderaan dicari MYVI 1.3 ezi PUTIH plat WSH 1781 .
register kat raub pahang.
Kenderan dikesan sekitar...
