my kancil' l2 temperature rise slowly when switch on the aircond but when turn off the aircond, the temperature decreses slowly, when this problem occur, I have changed new aluminium radiator, new fan,overhaul,flushing,direct power fan,check the wayering and grounding, and hoses but the problem still occur. can someone help and give suggestions?the termostat have been remove,i tried with normal l2 radiator,check the meter,every coolant,added extra fan,changed water pump-all these i have tried but still no solutions.head gasket changed,been to 5 mechanics and 3 workshop but still the same.Someone suggest to me to change cooling coil, does it related to my problem?
