Hyundai owner photo gallery
HMS
1,485
Penang
www.maxperformance.com.my
Actually the surbo thing is not necessary, and the improvement can be neglected. the intake air tunnelling in will not have effect when it reaches the end of ur intake manifold. Air spiral cannot make a 90 degree turn fren, it will oni spiral up to the part just after ur TB. When going into the 4 individual piping at the end of the TB, it will not have anymore spiral effect. If you have a chance, take at look at the Toyota 20V intake manifold, its awesome, factory spec have a spiral intake piping, spiral directly towards the 4 TB hehe. For elantra, we have 1 TB supplying air to 4 ducts via a 90 degree angle, so no use using the spiral. Maybe you can try removing ur surbo and see the pick up got difference.
The best and most simple way to get more pickup power or improve FC is:
1. More air inside ur tyres, maybe pump 230kpa (this is wat i do), improve the FC too
2. Carry the less load as u can
3. Dun let the gearbox change gear auto mode, i use the lever to control when i want to change gear to overtake.
4. so far i feel shell gives the best mileage
5. make sure ur extractor is not leaking, elantra extractor prone to leaking
6. remove the factory secondary airbox (inside ur fender), air intake will travel much smoother.
7. Denso iridium plugs can offer up to extra 20km per full tank for my car
8. always use OEM plug wires, those thick no brand don't offer any power improvement, but FC bad too. Unless u take Nology or NGK, those offers power improvement but i am not sure FC got affected or not. But Nology wires dun match with iridium plugs.
9. dun overfill ur auto-oil, gearbox will be damn heavy.
10. bypass the TB coolant intake hose, in hot countries no advantage.
11. bypass the PCV valve hose from going back to the intake manifold.
12. get a high flow drop in filter
more advance technique for NA engines:
hydrogen mixture air intake
heated fuel rail
heated then cooled down air intake
1st n 2nd item can improve mileage average 50% but not easy to implement and scare jpj kacau cos its modifying combustion
3rd item is still in testing, dun know how much good it can do in real world, but in theory, it could improve at about 20% FC
BlackSamurai
9,000 RPM
9,656
24
near 7-11
www.hcc.ne1.net
after some sad posting, here is what I promised.
Yu's report on bodykit upgrade.
Send for tuning before any started
Installation of kits at the workshop
Blitz side skirts
3/4 view
touch up
Bring it out for a sunbath? :biggrin:
Veilside spoiler + TRD rear lips
Realise the centra pole antenna? Yu's DIY work to re-locate the antenna because the Veilside spoiler block the Antenna at the rear
yes, you are right, bonnect mod as well
take a closer look, Evo 4 vented
Front look, TRD front lips
Before install wheel arch, just do the knocking
wheel arch touch up, Toyota WISH wheel arch
Send for spray work
Spray work preparation, uninstall all unessery stuff
TRD Toyota Wish wheel arch. After the base coat, still touching up
cover it up, Opsss! miss out some thing, touch up again
spray it baby: spray in progress
TADA....
another shoot
shining paint
rear
Finish, drive back home but raining, muahaha
another shoot with flash
good coverage by Yu.
Yu's Coupe have too many mod, I rather ask him to explain to you if we have chance to meet up with him.
end of report. Congratulation, Yu.
dartango
204
Kum, the combination of Denso Iridium Plugs & K&N Filters did some ass-kicking to my car & now it feels much more responsive. I wonder if doing Voltage Control & Grounding would further improve the performance & most important better FC...any indications??? How much better?
HMS
1,485
Penang
dartango:
yeah the Pivot VS and additional grounding will improve the torque and FC. This item use together is confirmed to offer improvement.
That iridium will roughly last you 40000-50000 km before the next plug change.
Daniel Lee
2,950
4
BS, did Yu changed all his car brakes?
I notice the Coupe had 5 lug holes sport rims.
Cool! I like those rims that Yu had on his Coupe.
BlackSamurai
9,000 RPM
9,656
24
near 7-11
www.hcc.ne1.net
Daniel, Yes.
Yu change the wheel lug position from RD1/RD2 4 x 114.3 to 5 x 120
Reason behind is because
1. he drool over a nice rim with 5 x 120 setup and
2. he wanted 235 tires at the front badly (235 must be at least fit with 8" width rim, our 4 x 114.3 max is 7.5" width with 225)
WTF! Hahaha, but he did it. This is his new rim,BMW AC Schnitzer Type III rim.
(PS: PCD 120 is BMW rim = expensive)
The original stock brake can't stop the Turbo engine in the time/distance he want, he change it to Front RX-7 brake, rear disk+drum brake
Cow
1,090
wow...
but omg, did they spray his rear antenna black too????
BlackSamurai
9,000 RPM
9,656
24
near 7-11
www.hcc.ne1.net
cow, welcome back,
as far as I know the rear antenna is not functioning, he is using the centra pole antenna, but i can't confirm that. :biggrin:
recently my 4G15 wira had low oil pressure, engine oil ever go to cylinder head.. can i ask any suggestion to increase my oil pressure?.. and this evening i open my engine oil pump, and i notice my oil pump doesnt have relief valve/relief spring valve.. does this normal to 4g15 oil pump? btw this is my 1st time opened 4G15. hope all sifus here will help me
