HWL adjustable problem, need help
butthead
2,910
howiechoo said:
all right then.....say wat u wan to...
if u think a high spring and damping rate will not crack the car body or minimum risk, then i think u should gain more experience on suspension setup and view more example....
okay...i concede... i do not wish to continue arguing since you and i stand firmly on our beliefs...it will not end up in a good way in the end i am sure if we continue...
LuKa
618
19
Kedah
the risk of cracking is very minimal.. just ur butt n teeth that will crack or fall off..
howiechoo
8,000 RPM
8,857
Bukit Jalil
it;s just a discussion..
dennisdreams
333
21
as far as all the HWL adjustable we received for service hasn't got any big damage done. slight low on oil level and minor leaking only. could give it a go. not recommend to buy APM adjustable (the reverse monoshock version) though. It's impossible to fix once it's shell wear out.
Target Design
436
Pahang
n
the seller said just over warranty...and he already bring to factory to services before warrant over...
so.,i think condition are still ok.
anyway thanks all the sifu here.....
thank you
butthead
2,910
a discussion could also end up in flames... so better stop before too late...
thank you
you should still give the condition a check before you make the deal.. most important is if there are any dents on the damper case... any scratches on the rod... other than that it should be fine...
is it any cheaper than buying a new set??? cos sometimes a new set is only a bit more than buying an old set and revalving it...
Target Design
436
Pahang
n
the seller sell me RM800....izzit worth or not with this price?
new one i think is RM1680
butthead
2,910
it is the best you check with them on the price of servicing a set of Waja adjustables...
then there are the workmanship price for installing the adjustables on your car... you add here and there... sometimes it is more worth buying a new set if it is only a bit extra... got warranty somemore...just my opinion
This car was stolen this morning around 4am..
if anybody saw this car pls call the owner A.S.A.P.. 012-4442409..
reg num-NAU 7818
colour-silver
go to this link for more info of the car..
http://www.zerotohundred.com/newforums/cars-for-sale/261128-wts-perdana-v6-twin-turbo-many-extras.html
thanksss..
