if nt mistaken,actually is a 2-pieces...
1st u hav to remove the radio panel den 2nd jz remove the whole piece from digital clock till meter there..
1st-
U MUS REMOVE TIS FIRST there are 2screw on the top of radio panel.. after tat unscrew both den u can take out the 1st panel redi..
those are a clip u hav to use sumthing to 'kiao' it out mayb a small flat screw driver but becareful is a plastic easy broken.. nt sure below ur radio the console thr hav any screw o nt..
2nd-after remove the 1st panel(adjust ur steering to lowest cuz make u easy to take the out the 2nd panel later),remove 2screw at the meter housing thr, 1 at left side of the digital clock(curve thr),another 2 at the aircond panel thr(after remove the 1st panel den u jz will c the screw)den u can take it out le..
when fitting back,nt to tight the screw too tight(jz agak agak can redi),it might make the plastic hole broken,careful with it..
i jz calling from my memory only mostly is like tat la..u can try 1st if cant den dont force take it out cuz plastic may broken..
HAPPY DIY:wavey:
