highest hp N/A VTEC in malaysia
rajie
1,290
15
pantai hillpark
hey guys was just wondering what is the highest hp mark did u guys reach with ur N/a machines
for track and also daily use .....how high can u push the N/a engine for whp
the highest wan i has seen is my friends old car WDN9970 250whp over 300 on engine
nksc
694
wat car is dat??:hmmmm:
D-IV
262
250whp??!!! wow... what engine and setup is he running. Sum more old car lagi.... hard to believe but it is possible.
nksc
694
if u got money and knowledge anything is possible..
rajie
1,290
15
pantai hillpark
its was a EG body the car was build by amoil
it seems the car can say was fully done up for an N/A vtec
D-IV
262
And that was on a single vtec?:banghead: jk...:smokin:
Anyway, i didn't say it was impossible...
fobs
3,752
8
bisimoto,... he did wonders with the f20b sohc vtec,...
but not in malaysia lerrr
nksc
694
bisimoto?? not in msia??
pening...:rofl:
bien335
1,819
48
1,648
Johor Bahru
F22a lah fobs.
F22A or F18A Non-VTEC engine built and tuned by Bisimoto Engineering, headwork by Portflow.com, Evolution Industries Heat Shielding intake gasket, Bisimoto Spec Web Camshafts, Bisimoto Spec Arias 17:1 compression pistons, KibbleWhite black diamond stainless steel valves, Bisimoto valve springs and titanium retainers, Webcam custom rocker assembly, Bisimoto exhaust rocker spacers, Bisimoto “no-slip” cam gear, Redline Weber 55mm dco/sp carburetors with 48mm venturis, Bisimoto custom intake manifold, MSD programmable digital 7, Howard Aluminum Rods, Darton MID sleeves in Golden Eagle 90mm machined block, Golden Eagle modified factory head gasket, Lopez crankshafts knife-edging and offset grinding, Bisimoto H/F2D adapter plate system, Rockett Brand 118 race fuel, Bisimoto custom header with Burns dyno-sys merge collector, Torco SR-5 5w-30 engine oil, MTF-L trans fluid, Houseman Autosport synchro to dog engagement conversion transmission with factory Honda 1-4 gears, houseman 5.0:1 final drive, Action 3 puck clutch with dual diaphragm pressure plate, NGK Iridium racing spark plugs, Bonaco AN fittings and lines, Barnes dry sump pump, Moroso dry sump pan, Evolution Industries 500hp axles, Innovate Motorsports datalogging system: LM-1, DL-32, XD-1
bottom line---> 450+ hp!
fobs
3,752
8
F22a lah fobs.
soli bos, me newbie
haha! i tot 300whp???
hahaaaaa! 450,... evelyone in m'sia go eat grass
guys, need help.
My car is 9gen altis, 2003,
I was driving for almost 2 hr, then smell some short circuit burning smell inside the cabin.
park the car at the road side , then i realized headlight cannot be turned off.
i quickly disconnect the battery to prevent further damage to my car.
it didnt gv any sign prior to the burning smell. and the smell came from the steering wheel itself, on top of the airbag area
anyone can guide me here?
