help ! Proton Wira 1.3 Dashboard Problem
jedi
108
Red : Problem, no light at all...
Blue : Good, no problem
any clue what happened ? if it's due to fuse, which fuse ?
I've checked the fuse box below the driver side, seems to be good.
ehdrian
I Don't Care!
3,310
280
1,683
Save your headaches and send to your mech.
jedi
108
bro but if we knows nothing and send to the mech, that will be a throat cut ... could be just a small fuse issue end up changing the whole dashboard
punk
360
76
528
Negeri Sembilan
The small bulb with blue condom inside might burn dy.:biggrin:
The bulb size not same with meter bulb ya.
it is very small, try to take it out if u know how to diy.
Then u can c the condition of the bulb.
Gently take out the blue condom, no one is selling the blue condom outside if koyak dy .:vroam:
hey guys,
i have a problem with my car.. the steering vibrates excessively from about 90km/h onwards.. i have changed new tires.. rims checked not bent, alignment and balancing done.. what else could be the cause of this? btw after doing alignment and camber alignment the vibration got stronger.. my car set up is 4agze custom made driveshaft on the left side to correct length but same spec as ori gze shaft.. right side is original gze drive shaft. bearings are relatively new.. hope someone...
