david, as suggested, i think you need to *fully understand the problem. then the solution is easier. without understanding the actual problem whatever questions you ask will not be satisfactory. its a straightforward solution.
there are owners who have 'similar' problems & as I have mentioned above (the checklist-the remedy) & pm'ed to you.
once your understand the problem, read what i have posted, it will be clearer. thanks hope it gets solved.
*the difference between SMT hydraulic actuator pump vs gear box /SMT oil vs gear oil
Bump: david, as suggested, i think you need to *fully understand the problem. then the solution is easier. without understanding the actual problem whatever questions you ask will not be satisfactory. its a straightforward solution.
