H22A engine Check Light ( EGR )
fobs
3,752
prehaps a leak
ooopsss,...
get it chked quick or risk overheating the engine,...
could be ur fans, ur water pump,...
many things,...
Lancerboy1
248
today went to Hv and no more CHECK light, replaced EGR valve,,. solved, as for water temp, fan is working, no leak, think its back to normal... hope so.. lets hope so.. =) thanks all..
ev3rgr4ce
189
Havin the same problem as you bro, where is the HV racing at? May need to change the EGR valve as well. Wondering if there's a performance difference with the EGR thing solved
Lancerboy1
248
actually u can take out the egr valve to clear off the carbon with a screwdriver, just scrub them off...
fobs
3,752
what screwdriver,... = toothpick???
mzsu
124
Regarding coolant in spare tank... just go and do pressure test on radiator...
If there a very small leak, it takes time to empty your tank....just RM5 for the test.....hehehehhe
eg9_05
1,163
just use something to access into the valve to scrub off the carbon..
bro ...........what is EGR....where is located???? isit the sensor on the exhaust piping under the engine??? :hmmmm::hmmmm::hmmmm:
fobs
3,752
that at the exhaust piping is the oxygen sensor,... o2 sensor,...
the EGR = exhaust gas recirculation
is located next to ur valve cover,... left hand top corner,... looks like a cup
eg9_05
1,163
sorry bro cant get where isit..............any pic that can help ..pls thanks
fobs
3,752
this is from accord enginebay,... not 100% sure whther the EG enginebay is like that or not,.. eventho i used to own an EG,...
Hi Guys,
need help...
looking for:-
i) Bilstein B8 Sprint absorbers Front and Rear
ii) Strut Bar
for my 2004 Honda Civic 2.0 i-Vtec;
or if there n e suggestion 4 a better absorbers and strut bar. TQ
p/s: I've already fitted eibach springs w OEM absorbers. The Eibach is very good and I think Im gonna keep it. therefore just looking 4 the absorbers that goes or fit ngam w the eibach springs.
Many Thanks.
