fuel regulator
avaultz
478
im using ori sard.
what the the best setting for my gsr 4g93t??? i dun really trust my mech.. lolz
n btw if u guys r planning to put "fuel press" gauges in ur dashboard instead of at engine bay, Plz dun buy "auto gauges" brand.. the sensor adaptor is to big for sard. i had to custom make another adopter for it- > rm35... lolz...
others brand like apexi,defi can fit in nicely...^^
wasteg4te
154
9
jb
err.
what will happen when i install powerfull fuel pump such as walbro, but no fuel regulator.
is it any problems can happen?
and another things with is better
walbro fuel pump
bosch, or sard for sr20det (stock engine)
GT_AUTO
3,503
71
K.Trg
www.facebook.com
usually there's no problem.just need safc to fine tune it.the con of not having
fpr,u can't regulate the pressure at the fuel rail n u don't know the pressure.
all those fuel pump that u mention r good pump.
Satria SE
113
All sifus...
Any idea whats the right psi for a 4G15P engine....?
Currently at 4 psi...sig diffrence at high rev but hv some unsuall noise from fuel pump b4 starting and during operation...
edwin_lcw
1,242
Setapak
if one usable n can last long ones how much will it cost for one f/regulator for 1.5 eFi wira ?
GT_AUTO
3,503
71
K.Trg
www.facebook.com
i think the bolt-on type is much more durable then the external 1 cos it use
back ur oem diaphragm.con is u wont get the pressure as hi as those external
1 lar but more then enough for 4g15.
edwin_lcw
1,242
Setapak
icic thank you for the advise ... bolt on cannot adjust as u like one woh then got no meter one issit ? adjust already then they don`t adjust again
GT_AUTO
3,503
71
K.Trg
www.facebook.com
yup,bolt on 1 got no meter.if u insist,u can bolt the meter at ur fuel rail.
for 4g15,u need a pressure slightly higher then ur current pressure only.
Hi,
Just had my second dyno session yesterday, drilled a hole in the exhaust extractor manifold after the turbine with wideband O2 screwed it up right to get better AF reading. My spec:
4G93T, standard 0.7 boost, standard mini side mount intercooler...
modded: Walbro 255 LPH pump, FSE fuel regulator, 2.5 inch piping, KNN closed pod, megasquirt standalone, removed restrictive air flow sensor.
the first dyno i had few weeks back was 195 HP, that's without tuning, and yesterday upon...
