Engine oil getting lesser
vantageX
103
mengz: why do you need two oil catch tanks? Does your catch tank have its own air filter at the top?
What is your current oil catch tank connected to?
Doink
3,492
House
simplythebest said:
Yo there,
Same here, not going to overhaul the engine, is a retarded 1.3 engine.
Actually, my mech advise me to drive at moderate speed from now onwards, the engine condition is still ok, just that don't drive too harsh, like whack 6K RPM all the time.
Mileage only 88,000 km's.
Your engine oil getting lesser too? I change my engine oil every 4,000 km's now.
seems like ur car didnt run in too well during initial breaking in period...or u can check if ur engine got dirty or not with oily stuff at any part of ur engine...that shows ur gasket is bad and need replacement...ur engine is still new...
u dont need to change engine oil every 4k...just change at normal 5k...and keep the spare oil after each change...to top up when u check the car engine oil is low...
gogo2
31
My engine oil also getting lesser and lesser very fast last time. All shop ask me do top overhaul. But I keep on asking everyone. Then I found one place. The mechanic ask me to change valve seal instead for RM1xx. It doesn't involve opening up engine. So after changing, no more oil missing. Furthermore, during the changing of valve seal, I change my engine oil from mineral to fully synthetic. I think I'm kinda crazy that time.
mengz
605
i dun have one now, but im planning to get one and i've been reading on the net, usually the oil catch tank is connected in between the PCV valve and the intake manifold. so unless any oil catch can in the market has 2 input and 2 outputs, then i can route the breather hose into the same oil catch tank.
huakenny
LB Performance
9,126
240
Kota Kinabalu
u can customize the OCT...so u only need one OCT......ehehe
kyheng
1,202
seremban
Seems like every one here have left out 1 very important thing on the engine oil lost.
Some background of engine : everything that rotate will have wear and tear include the piston rings. If the engine is rev to 4.5k and above regulary, the piston rings sure will wear faster and creating some small gap between the holder and piston.
Engine oil will change its properties when hot it will become lighter or more technical is the viscocity of the oil drops. So when the oil is hot, it will slip in to the combustion chamber and burn together with petrol. Depending on how much the slip-thru is, lesser we won't see any white smoke. When the gap is big, then we can see alot of white smoke. Petrol will tend to slip thru to engine oil also if the gap is big and make the oil become lighter. This don't have actual proof as the petrol in contaminated oil will booil off when the car is moving. So the best is don't adjust a car's timing more than factory default. If the enigine is vibrating, maybe is caused by other problem.
Below are the examples of engine consumption on an old car(8 years and above) based on normal wear and tear or an uncle cars that never rev the engine till 4.5k and above.
If we use syntactic oil(Shell Helix Utra or similar), the oil will only last you for 1-2 weeks or the lost is 50-70% as viscocity of the oil is lowest.
If semi-syntactic(Shell Helix plus), the lost will be around 30-50% as the visco is higher.
If use the lowest grade(Shell Super Standard) the lost will be 20-40% as the visco is highest.
As wear and tear we cannot avoid, at the same time want to save money for the top overhaul, so the best way is add addative to the engine oil to bring up the viscocity. Then the lost will be lesser. Like my Wira 2003(done 95k), when using semi-syntactic oil the lost is around 10-20%, if add the addative, the lost is lesser at 5% only.
vantageX
103
You got your crankcase breather and your cylinder breather hoses right. Use a T joint which you can find in hardware shops or somewhere else and connect the two hoses up. A T joint has 3 connections so you have one connection left. Connect this to the oil catch tank's inlet. And the outlet is connected to your PCV. Remember seeing such a set-up on an old Austin Allegro. The Allegro had one pipe coming out from the drivers side of the engine near the clutch assembly (crankcase breather) and one pipe coming from the cylinder head cover. These 2 pipes met at a T-joint which then led to the air filter.
kyheng: Good points. But just wondering why do you still use a semi-synthetic and then add an additive to thicken up the oil? Doesn't this just defeat the purpose in the first place of using a semi-synthetic?
It has been said in the past that even new cars with high-mileage can switch to a lower grade oil to improve oil consumption and to make up for wear and tear.
kyheng
1,202
seremban
Well, you got the point, but if use lower grade oil, the engine temp will be slightly higher, if use semi syntactic the temp will be lower, that is why I have to use like this. The addative is to bring up the viscocity, but will not affect much of the oil other properties. You might feel the car abit heaviey is use lowest grade, but if use semi + addative is still like you are using semi only.
Actually in order sense, is useless also, as the addative is cost 12-1++ and have to change every 5000-6000km. Is abit subjective on this, so have to depend what we want, but if the leak is big, is better to add the addative.
vantageX
103
I see, what brand of additive are you using? Sounds like you're using it to stop a leak? Would it be No Smoke? The price sounds about right for No Smoke.
kyheng
1,202
seremban
The price is around 14-20, as said earlier, as said earlier, oil tends to slip-in to the combustion chamber due to piston rings wear and tear(this applied to new cars also). If the gap is small, the slip-in is less which is my car facing now. The addative is not used to stop leak, is used to make the visco higher, so if the car is running with the engine oil is hot(maybe 70°C), it will not so fast and easy to slip-in to combustion chamber. Thus the oil will not lost in short time. If really a big leak where using addative also cannot control, is better to do top overhaul.
Engine oil got certain visco index at certain temperature, the number in the container is at ambient temperature or 15°C, say 40cst. When the engine temp become 70°C, the visco will go lower, say 15cst. So at 15cst it will move/flow faster than 40cst.
mengz
605
instead of adding additive to make the viscosity go higher, y not just get an engine oil which has high viscosity? i remember i read somewhere when an engine oil contains too much Viscosity Index Improvers(VI), under high temp & shear forces, the molecules of the VI tend to change shape thus lowering the quality of the engine oil gradually. also, how much viscosity will the oil additive add? what brand issit u using? does it state clearly by adding how much, ur bringing up the viscosity by how much?
also, ur above post, u said a car with shell helix ultra will lose more than shell helix plus and super. i think u kinda misunderstood engine oil viscosity. actually, shell helix ultra and shell helix plus both are 15w50, only difference is one is fully-syn and the other is semi-syn. shell helix super is 20w50. the only difference is the W which doesnt make much difference here in malaysia. so how come shell helix ultra loses more engine oil than the other 2? all 3 engine oils are 50 viscosity at operating temp. so why do u say shell helix super has the highest viscosity?
vantageX
103
I asked about No Smoke because No Smoke is used to help cars with smoking problems hence the name. It works by temporarily sealing the gaps between the piston rings and cylinder walls and in other words stopping the leak of engine oil into the combustion chambers and stopping the smoke.
But because its poured into the engine, it also mixes with the oil and viscosity becomes higher. But in a car with a smoking problem it doesn't matter because the car is already losing power because of the compression loss thru the pistons. With the oil being thicker, the compression is returned and so is the power.
kyheng
1,202
seremban
I don't want to argue much on this, as before I change to Wira, I drive a 94 Iswara, all the above mentioned oil I have used without adding addative. The result is using fully syn-oil have to top up another 2liters after 2 weeks, semi-syn have to top up 1liter after 1month and lowest grade no need to add. I complete 5000km around 3months or lesser. You can find out this with your mech on how true is my statements.
Another thing is if I not mistaken, the engine oil temp is more 50°C when the car is running.
http://www.twf8.ws/new/tech/tip/enginetemp.html
Just get the info from this website, the temperature is at 90-110°C.
If use the lowest grade for 3 years engine, you will feel that your car is abit heavy and response slower, if use syn oil you can feel that your car is like flying.
Frankly speaking I don't know what is the 15w50 or 20w50 stands for, maybe like you say I misunderstand it(I'm sorry for this) But I'm type of man that try and error, futher info you can check below website:
http://www.bpoil.co.za/products/engine/vanellus/c6global.htm
From the spec(10w40) you can see at ambient temp the visco is 106, when at
100°C the visco is 14.
You can also check Shell's website for the correct oil for the age of a car:
http://www.shell.com/home/PlainPage..._lubricants/helix_new/app_choose_ga_0312.html
You see, they only recommend you to use lowest grade for a 10 year car. Why they never ask you to use shell helix ultra?
http://www.blackstone-labs.com/oil_viscosity.html
I have read few times already on this, I cannot understand it... Haha.
From the above article also they not recommend we to use the addative. But the addative that I buy normally is around 50-100ml or lesser, brand NASA. maybe if the addative keep too long it will degrade, but my usage is fast, every change only takes 3months or lesser. I only come across to use the addative when I know that the engine oil lost 20% after 3 months. So after adding it, the lost is around 5% now, without performance drop, I have use 1 time the lowest grade and I feel my car abit heavy.
vantageX
103
Nah, not arguing here, just a fascinating topic. I guess nobody is right and wrong here and even the most experienced mechanic can't tell what the best solution here. There are so many variations to play around with, temperature, driving style, condition of engine, tune of engine, types of oil, additives and so on and so forth.
However, I do have to disagree with Shell's system of recommending oils based on just the age of a car. Eventhough a car is new, it can still have an old design engine in it or the other way around, an old car with a revolutionary engine for its time. I guess for the average car user out there the Shell guide is ok but I don't think we should take it too seriously. The other websites are a good read though and should be read by anyone wanting to learn more about engine oils.
kyheng
1,202
seremban
Yeah, but basically, old car cannot use fully syntactic oil because of low viscocity or too light in another term. You can try without adding ant addatives, but don't regret after this. The Shell system fault is they never tell us why old car cannot use syntactic oil. Being a company that selling luboil, not only Shell, they should speficy more clearly on this, atleast we will be more aware.
Another thing that you get it wrong abit is the engine oil used is corresponding to the age of engine, not the age of car. So the design of the engine is not a matter.
I think is better that we test around with the oils(syn, semi, standard) then we make the conclusion ourself. The process might be long(1year) but atleast we know which oil is better for our car engine.
Back to the topic, this is 1 of the main cause that we lost the engine oil if wrong grade is used.
Dear Sifus,
I had problem with my car paint. hope somebody can help me to solve my paint issue. it has some serious pitting issues that seriously made the car looks not appealing. what should i do?
Should i just wet sand the entire car to smoothens the surface of the painting.
