Engine Mod or ECU Mod
Casey Tan
Jun 21, 2012
7
Hi to all sifu here, i driving a neo cps, my current setup is:
K&N Open Pod Filter
Iridium Spark Plug
4-2-1 Extractor
R3 Muffler
in future i planning to enchance my car's performance, but i should go for cam pulley, crank pulley setup or skip the pulleys direct go for ECU mod.
Pls advice, thank you
Rily
43
Hi Casey,
Mind to share where and price you get the mods you've done, mine's still stock.
Thanks.
Casey Tan
7
Hi Rily, i done my mod at Seremban Advan Race,
K&N Open Pod + Piping RM440
Iridium Spark Plug RM180
Extrator RM430
Muffler RM400
nadziad
287
28
528
johor
ecu mode....tweak some ignition timing and idling timing....ur cps can go faster than stock......
Casey Tan
7
thanks to all sifu here, for myself i really wish to go for both mod, but my budget only enough for either one, so i hope to hear more option from you guys. Some more i found out, install adjustable cam pulley without an aftermarket camshaft, is it can't bring out the performance. Pls correct me if i'm wrong.
boi
368
26
go for engine mod 1st then compensate it with with ECU mode...
that if u dont want to tune twice...
Casey Tan
7
Thanks everyone, i think i have the idea what to do with my car, thank you so much!!!
crazykatak: thanks for your offer, when i want to buy ECU, i'll contact u...
nasilemak_addict
29
8
1,503
I have a Haltech Interceptor Piggyback ECU for sale. Was taken out of another Satria Neo (from a very limited edition version). This ecu helps you to improve engine response and also increases engine efficiency. Don't have to mod your internals to gain extra power. Interested ?
phantomRX8
Insignificant Fool
331
5,018
ISS
Anyone changed their neo cps ECU to R3 tuned ECU ? How much is the price
Sent from my HTC One using Tapatalk
Following are some ECU I have repaired. The write up is to assist DIY members with ECU troubles.
Will update everytime a ecu is repaired. Tq
Honda ECU with CEL22....
