Both also need highly skill if anything wrong you will have big problem.DanzEterna said:the only thing u could do to the block is skimm & rebore it...
Ya I agree make it right at 1 time. We not sure how is the engine condition before you go for full overhaul so it much depend yr pomen advice. Re-build engine not everyone can do it because it need experiance & skill to it.BE5RSK said:Sound like fully engine rebuild.
since the entire engine fully dismantled, perhaps you might want to change the engine bearing, check/replace the rods to stronger one, balance/counterweight the engine crankshaft, and change the engine studs to stronger one.
Do it once, and do it right (and completely)
