Engine and gearbox vibrate when passing through watery
May 10, 2022
45
Hi there.. im doing k24 swap into my civic fd about a month ago. im having few problem.
1. whistling sound near right front when high rev ( above 6500 rpm upward ) - suspect driveshaft bearing .
2. Engine and gearbox vibrate when passing through watery .
There is no problem of vibration if speeding the car on dry road.
You DIY-ed the swap? If not why not go back to the shop to fix it for you?
#1 is a bit hard to troubleshoot without hearing the sound
#2 maybe it's a ABS sensor issue?
condifent2022
45
tq for your kind response. till now my mechanic is trying to figure out what when wrong... and yet they still could'nt find any solution. i've change the tie rod end and also a set of FRONT LOWER ARM BUSH "BIG / "SMALL" , 2 pcs of stabilizer link.. and till now i could'nt run my car safely on wet condition. it will skid to the left or right if i run through
pile of water.
pile of water.
The ABS sensor?
Ever experienced engine stall with air-conditioner on when you car slow down? What if its happen at the moment when you in a middle of U-turn? I bet your heart will pounding rapidly.
FICD is a little device that will help you with this problem. The concept is, this device will allow vaccum leak by allowing more air into intake manifold hence engine have enough air and wont stall. Its also stabilize idle and drive will feel a little bit lighter with a/c on. For the one who familiar with...
