DIY My Simple CAI.
bigroom
62
Originally posted by slk850+Mar 7 2005, 12:28 --></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (slk850 @ Mar 7 2005, 12:28 )</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-bigroom@Mar 7 2005, 10:34
may i ask....wat is dat (circled) used 4? air compressor? 2 vacuum meter? where u got it from?
Ok, this small filter actually is used on EFI engine. For better air flow smooth go in injectors.
But i use it for : Since i change to open pod air filter, there is a hose that connect back to original air filter box from engine bay. But it can't connect back after i used open pod air filter, sometimes when then engine's oil was too full/high rev. Some engine oil will come out from this hose, and spread it on everywhere on my engine bay. Thats why i use this small filter to stop those engine oil spread out and let those burned gas go out with a transparent pipe (for fish tank use). And i dun want those burned gas go into my Air Filter. :P
That small filter can get it from any mech places. RM10 only.
Hope my answer doesn't confuse you.
Did i answer your questions ? :) [/b][/quote]
ya sure, tanx. i hav 1 like dat 4 my air compressor. jus din noe where 2 get a new 1.
slk850
885
Penang
Originally posted by bigroom+Mar 7 2005, 15:02 --></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (bigroom @ Mar 7 2005, 15:02 )</td></tr><tr><td id='QUOTE'>
@Mar 7 2005, 10:34
ya sure, tanx. i hav 1 like dat 4 my air compressor. jus din noe where 2 get a new 1. [/b][/quote]
Welcome, sure you can easily get a new 1 from mech place or accessories shops. :)
tykoh
351
Ipoh
tykoh88.blogspot.com
Originally posted by slk850+Mar 7 2005, 14:15 --></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (slk850 @ Mar 7 2005, 14:15 )</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-tykoh@Mar 7 2005, 13:30
nice design man... i like the RAM pipe extension... currently i just use 3' pvc pipe as my extension... this is neat and really nice... bravo job!!! :P
:lol: :lol: Thanks, not so bravo lar..... :P
Benefit with this curve extended Air Ram are you can point your Air Filter to diff directions (depends where is your cold air intake).
MPower customized it for me. :) Price around RM35 ~ 40 (Price are not fixed) Hope you all understand. B) [/b][/quote]
wah i really like the curve air ram.... and its really affordable... i was looking for it quite some times ago when i try to extend my open pod filter... but now i just use pvc pipe... really ugly lah... but its functionable lah... :D
after change to open pod the sound of intake so great when full step on the gas.... so syok... :D
nicely done man...
yinho
382
Originally posted by tykoh+Mar 7 2005, 17:45 --></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (tykoh @ Mar 7 2005, 17:45 )</td></tr><tr><td id='QUOTE'>
@Mar 7 2005, 13:30
nicely done man... [/b][/quote]
customize wan ar.. means kenot get from accesories shop izit? i wanna get one ler.. :(
slk850
885
Penang
Originally posted by yinho+Mar 7 2005, 18:14 --></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (yinho @ Mar 7 2005, 18:14 )</td></tr><tr><td id='QUOTE'>
@Mar 7 2005, 13:30
nicely done man...
customize wan ar.. means kenot get from accesories shop izit? i wanna get one ler.. :( [/b][/quote]
Is the same pipe u get from accessories shops, then need to cut it shorter base on the length you need and fit into your engine bay. Thats i called it customized. :)
yinho
382
Originally posted by slk850+Mar 7 2005, 20:27 --></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (slk850 @ Mar 7 2005, 20:27 )</td></tr><tr><td id='QUOTE'>
@Mar 7 2005, 13:30
nicely done man...
Is the same pipe u get from accessories shops, then need to cut it shorter base on the length you need and fit into your engine bay. Thats i called it customized. :) [/b][/quote]
did u see any straighter ram pipe? around 2 palm length
drexchan
2,908
100
3,163
Bukit Jalil
drexchan.fotopic.net
My CAI project:
Pic #1: Stock pre-filter intake system on Wira 1.5 EFi. Long, U and L-turns, irregular shape and diameter. No way...
note: the silver portion is painted.
drexchan
2,908
100
3,163
Bukit Jalil
Pic #2: Modded pre-filter intake..
Materials:
Used S-hose from MMC (the S-hose after filter, going into the TB).
Hose clamp
3.25" ID industrial hose (8" long)
Epoxy adhesive
drexchan
2,908
100
3,163
Bukit Jalil
Pic #3: Upclose
The green wire is to hold the white-color 3.25" hose. The hose doesn't run all the way down to the bumper, but slightly longer than you can see for the colder air in the fender area. I have tried various setup. It's NOT neccessary to have the opening behind the bumper. Just make sure all the possible holes around that area is sealed, leaving a front one for fresh air from the bumper.
slk850
885
Penang
Where is the ending ?? My friend (wira) request for it.....hahahahaaaa :lol: :lol:
drexchan
2,908
100
3,163
Bukit Jalil
1 inch longer that you can see from the photo.. should i say.. slightly lower than the head lamp. this mod is not cheap. you need to get the used S-hose and the airbox from half cut. Must be the MMC type.. Not siemens type. Around RM60-80..
note: sorry bro slk850... for hijacking.. haha!! As long as we share right?
slk850
885
Penang
Bro, any photo show the end of your CAI pipe ?? where you located it ??
Aiya....wat hi-jack woh ??? It on the right topic - DIY CAI.
:) :D :lol:
I can ask my friends (Wira) refer your DIY. Thanks for sharing. B)
anyone can quote me the price they got and from where?
i wana install and might have to remove on the same day.. if its too low..
