DIY - Install Vacuum Meter
jaywat
1,329
No...i just leave it like that only...i cannot find anything around me to make the cover....maybe will DIY a cover for it very soon,....using...coke tin.... :lol: :lol: ...why???
HEre is the pic of connection...
The orange air hose is connected to the microcompressor...i tap from there instead of pcv hose itself because i don't want to cut the original black hose mar B)
fishfan
16
[snapback]852353[/snapback]​
Where did u get the T-Joint?
From car spare shop ?
khguan
4,818
26
Seri Kembangan
fotopic.net
jaywat,
i just use black matt sticker to stick around de meter.. looks better than de original color.
fishfan,
de T-joint u can get it from hardware shop... but jaywat's T-joint seems a little diff... 2 big n 1 small joint... come together with de meter?
jaywat
1,329
U can get the t-joint in any hardware shop...but those t-joint mouth is bigger, so the hose come with vacuum meter cannot fit in... :)
But don't worry..all u need is come with the meter..in the box B)
jaywat
1,329
Originally posted by khguan+Mar 30 2005, 11:08 --><div class='quotetop'>QUOTE(khguan @ Mar 30 2005, 11:08 )</div><div class='quotemain'>fishfan,
[snapback]853264[/snapback]​
[/b]
<!--QuoteBegin-khguan
@Mar 30 2005, 11:10
jaywat,
hey i noticed dat u r using de same grounding kit as me... :lol:
[snapback]853268[/snapback]​
[/quote]
Wahhh u r so observant...yalo...the t-joint got 2 side bigger mouth one...smaller one connect to vacuum meter..u judge from size of the hose i guess ;)
That is the grounding kit i got from pasar road hoho B) ...the label got a lot of japanese words one...but i still believe it's china product :lol:
khguan
4,818
26
Seri Kembangan
fotopic.net
i used a T-joint b4 mah... then i know lar..
icic... yah.. confirmed its from china.. i using it also.. but it still works.. heheh.. pasar road seling for rm48.
jaywat
1,329
The cable is so thick, even it's not pure copper also more than enough already la...this is what i think... :D
khguan
4,818
26
Seri Kembangan
fotopic.net
well.. it is 6 gauge cable.. considered normal lar..
one thing i dun like bout this grounding kit is de length of it.. for wira.. it seems a little messy on de engine bay...
jaywat
1,329
[snapback]855845[/snapback]​
huh :huh: cable like that thick still 6 gauge??? cannot imagine how thick is 4 gauge ler...yea...the cable is short! can hang baju inside engine bay ler :P
khguan
4,818
26
Seri Kembangan
fotopic.net
de skin is thick mah... 4 gauge cable is slightly thicker.. but inside got much more copper...
u know lar.. china goods always wanto look good.. but actually not dat good.. :P
kruger
521
A.Setar
wah,.... jaywat and khguan are using the same grounding cable like i do... got it at bukit mertajam for rm45.... =P
jaywat
1,329
[snapback]856597[/snapback]​
Means many ppl is using the same grounding cable le hahha :lol: :lol: ...that time i bought using RM50 tot....hmmm <_<
jaywat
1,329
Originally posted by khguan@Apr 1 2005, 23:39
haha.. dat thing is mass produced mah... so it is normal lar we use de same one..
i bought it at rm58 leh... <_<
[snapback]860895[/snapback]​
Muahahah :lol: :lol:
Dear sifu,
After I install the central locking, my door lamp function when door open. Door lamp cannot function when i switch on... central lock is ok... Do my wiring got problem? because 4 wire i only use and 1 white wire no use...
please help me.. dear sifu...
