DIY Honda ECU Repairs- P30 P08 P27
stupiddog
200
aiyo.. no need skill la.... hahaha just make sure ur soldering the correct stuff...
E-Tech
1,115
256
3,183
Johor
I started from zero.
If want to learn, sure can mah.
Last time ppl say "ECU", I also worry...
But from small rev cut modification--> Chipping--->and now Repairs..
Not that difficult...reminds me of Phua Chu Kang saying.... "use your blain, use your blain"!
slackernel
76
hehehe... u motivate me... now i'm going to chip my p08, can u all advice me? :wavey:
augustine5677
9
Sir ,,u got ECU P08 Transistor LM2940T -5.0.
I got can u sale to me..and how much cos my the transistor.
Thank you .
E-Tech
1,115
256
3,183
Johor
Slack...
P08 chipping is easy... but need the parts...
You need...1. the 28pin IC socket.
2. the chip
3. Latch ic.... 20 pins
You car wat spec? I see if I have the suitable chip for you and do you have a vafc?
If you need, i can send you the items for a fee... must cover my cost mah...
---------- Post added at 07:22 AM ---------- Previous post was at 07:14 AM ----------
Augustine...
What is the problem with ur ecu?
I can't seem to find that part on the ecu... what is the location on the board?
Q......?
---------- Post added at 07:26 AM ---------- Previous post was at 07:22 AM ----------
August...
Okay... IC12, it is a IC..
Yes i can get it.
How many do you need?
E-Tech
1,115
256
3,183
Johor
slackernel...
Yes need to jumper J1, then the ecu will know you are use "external"vmemory- the chip.
Just use a short pcs of wire.... okay TQ
Augustine,
How many pcs you need?
Rm5/pc + rm0.50 postage + rm1.50 profit= total rm7 to your door step TQ
E-Tech
1,115
256
3,183
Johor
Updates....
Another ECU P08 was successfully repaired...
Problem: CEL on and cannot start.
Replaced: IC12...
jombiee
950
13
Ghombau
Bro, I have pr3 ecu with chip, need your advise
I think my chip still refer to the o2 sensor so i need a custom chip, my o2 sensor keep sending CEL & cant resolve it(even with standard ecu)
rpm cut at 8k, no speed cut
ignore o2 sensor. pls pm me the cost &
I will using VAFC as piggyback.
cheers
E-Tech
1,115
256
3,183
Johor
jombiee,
Pls understand that i do not do programming.
So you request I cannot do.
All the chip I have..feels, jun, mugen DO NOT have the o2- disable.
Normally what is disable are the knock sensors and speed limiter.
What you request can be done but that is not the correct solution cause you Fuel consumption will be bad.
What CEL do you get? CEL 1 or 41
If this is the case the correct way is you should be replacing your O2 sensor.
I have a long PR3 ecu and have chipped it, not problems....
Pls fix your o2 sensor. TQ
jombiee
950
13
Ghombau
yeah its CEL 1, change it already, even do a bench test, voltmeter test, everything is fine, even discussed it at Hondatech, still no solution, change ecu also did not solve the problem.
anyway, so you have any chip for pr3 ? could you install the ZIF socket so that we could easily change the chip ?
ZIF Sockets
E-Tech
1,115
256
3,183
Johor
In that case, i would say it is the wires.
Need to trace it from da ecu to O2 sensor.
The p30/p08 chips seem to able to run on the PR3 that I have.
What your engine spec?
Zif socket.... no i do not use those. I just use the normal type of 28pin socket.
You need ZIF sockets only if you always change chip... do you really need those?
Where is your location? TQ
I've been searching high and low for those transparent plastic/acrylic office blind rod which enables u to open or close the blinds. I wanna know where in KL or PJ can get it?
