DIY Fiat 600D restorodding
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
cant wait for it to be installed :driver:
noripsni
32
19
8
64
yah, I need it to make sure my fender flares are right..... like this car
The piece looks wide but on that picture of yours it looks small. I was thinking it would jut out in the front more
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
noripsni
32
19
8
64
I'm going too, I'm halfway on the front fender flares, and need the front box to finish correctly, if you look at my earlier pictures you can see I have added more metal at the front bottom, I think this grey car was built for the earlier front box with 'whiskers' and had the later wide body box fitted later............ heres one done how I like it.
  • Like
Reactions: ^pomen_GTR^
noripsni
32
19
8
64
earlier 'whiskers' type small box, Abarth just exploited the rule book, the 600's started with small chin rads onnt e 750TC, then went to this type on the 850TC, and finally to the big wide body one for the 1000TC and 1000TCR
........ I'm building my car as a cross over model from 1000TC to 1000TCR
  • Like
noripsni
32
19
8
64
todays work was finishing front fender flares as far as they can go without the front box as pattern, also finished welding the rear window frame and check fitted the glass.
  • Like
Out of curiosity, how tall are you @noripsni ? Cuz the Fiat looks kinda small, wondering how someone your height could fit comfortably inside? Or are you going to modify the seat position too?
noripsni
32
19
8
64
there is loads of room in these cars........... even with stock seats, 6ft can fit easily.. on my car i have cobra classics, sitting lower and further back. 500 also has lots of space, actually better than a mini
  • Like
Reactions: Izso
noripsni
32
19
8
64
the main issue is peddle space, as the wheel arches on both 600 and 500 intrude, so slim shoes are needed for quick driving, cheap sandles are no use
The car looks small but it does have a high roof....
Understand what you mean. I am big size myself and have driven car with closely fitted pedals before, keep stepping on 2 pedals......lol
noripsni
32
19
8
64
its not just high roof, the fact is there is no engine or gearbox in the front, so the front floors go way forward...... almost to the front leaf spring
Now i using NGK plug cable come with my half cut engine. My engine keep on jerking on 1st, 2nd and 3rd gear when the car are slow. I asked my mechanic he said maybe is my plug cable rosak.
I wan to ask shifus here which plug cables are better then NGK. My engine is Honda Vtec B16A. Location at JB. Tell me the place where to buy it.
Thanksyou.
