Dirty engine...
NiCkY7
821
er... a look like new engine wont give u extra power...
but when washing and accidently something happend, it will need some "power" from ur wallet...
use cloth to wipe, dun straight away and use water to spray... :D
SloMo
148
63
3,028
mix water with diesel / "minyak tanah" spray it onto your engine bay then wash with water... works fine... just for info certain car wash use this method to wash your engine bay...
boggysv
2,025
just dont smoke :lol: :P :ph34r:
alantan
3,573
15
kl
if you want cheaper solution to wash of stain..very effective
buy a little of petrol but you have to be very careful because petrol is highly flameble.....don;t pour directly...use those spray instead...spray to the dirty stains..and let it be there....then use soap water to wash the petrol away before you rinse it with water....
water and petrol don;t go together
that is why we use soap water to wash away the petrol before we rinse it with water...so when we rinse with water ,soap water will pull the petrol molecule along..make sure you completely wash off the petrol before starting your engine..
you don;t want your engine to catch fire ma...
wash hard and wash safe :)
xcheong
1,650
aiya just send to car wash to wash for u lar
RM10 only mah.
just make sure the cover your distributor and alternator for u.
phat7
2,122
62
cover alternator and intakes with plastic bag before attempting any work that involves water in the engine bay. Once finished make sure you remove the plastic bags before you start or you'll have melted plastic in your engine bay---> not cool dude!!!
I encourage you to do your own cleaning coz it increases the feel of ownership and besides these stupid car wash ppl really are not technical and they'll usually "GOSOK" you engine including connecters and all. After that you'll have loose connecters etc.
I want to put some 25mm wheel spacers on my car. I just know that I could run into issues with rubbing the wheel well. I would like to eventually BONOS kit. I'm guessing this will cause problems if I put in wheel spacers. I currently have the stock 17'' wheels from Honda as well. Is it possible to run a wider tire with spacers? So many factors. Does anyone have knowledge or experience with this? Thanks.
