im not sure if this brand...i also cleaned up my air flow sensor its really coated with oil...maybe cause of KNM use oil ,so must gradually check the sensor condition....i used normal contact cleaner in market...its help...
Hello all, I'm currently using a GSR Turbo with TD05H E3 turbo. Using E-Manage blue for tuning and running at 1.1 boost. I'm using E3 fuel injectors 510cc. Blitz boost controller.
I thougt of upgrading to higher topspeed. Curently I'm getting 210kh/h @ 7,000 rpm on stock GSR gear box. What's all the sifu's advice on this? Should I go for E3 gearbox? Or E1..E2 gearbox? Or just chg final gear ratio and add LSD?
What's the recommended boost? If I boost 1.5 bar, should I change the...
