car service checklist
Oct 27, 2005
my car is reaching 70,000km mileage and thinking of getting my car serviced, i've got a guideline from directional to service my citroen zx.
Engine Oil
Oil Filter
Transmission Oil
Auto Transmission Oil
Coolant - All Model
Brake Fluid
Spark Plugs - BX, ZX, Xantia, XM 2.0
Spark Plugs - XM 3.0
Air Filter
Power Steering Fluid - ZX
Timing Belt - ZX, Xantia, XM
Has anyone actually changed the transimission oil/brake fluid/power steering fluid?
TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
Engine Oil
Oil Filter
Coolant
Air Filter
Timing Belt & V belt
sparks plugs
The items yiou listed should be replace but not sure about your timing belt and V belt. I got mine changed at 80K.
ken12292703
Drives a shopping cart...
1,542
8
5,138
SoMeWhErE
Transmission fluid must be changed for smoother gear change and longer life. I change my brake fluid every 9 months myself. Brake fluid must be changed every 1 year same as your radiator coolant. If water sips in your brake system to the brake fluid, then something really bad will happen in the long run.
nitrus
2,895
35
1,648
may i ask something ..... is it bad for our engine if we change engine oil brand ?
i heard tat we shud use back the same brand of engine oil all the time?
plz advise, tnx...
ken12292703
1,542
8
5,138
SoMeWhErE
plz advise, tnx...
Hie, i have changed my oil from Castol to Shell Helix Plus and the feel is great. A smoother engine run and a queiter. Hope it won't do any damage. I think it shouldn't be a problem.:X-:
nitrus
2,895
35
1,648
good to hear ur engine run better! :_: i also like Shell ... but the proton centre i send to service use Petronas Syntium engine oil i think ....
i think i'll change engine oil also !! but i think if change once of twice lidet ok la ... not everytime also change ...
anyone tried Q8 Oils before? or Motul ... is it really that good...?
Trust me, I had the same expression as you, “WTF, is that real?” Well apparently it is real, the fact that its upside down that is. Taken at the Moscow International Airport, it is not known whether the car is real or made out of plastic, but I reckon it’s plastic. I doubt if Mercedes really would stick half a ton of E-Class on a ceiling. It’s a really good marketing propaganda if you ask me, we...
