Brand New Stepper Motor aka Idle Air Control Valve
DDT
********BUMP*******
Engine cold start failure?
Engine idle stall immediate, after switched on the car Air-cond system?
Engine rough idling which is suffering the heavy electrical load in car?
Than is time to check your IACV sensor aka stepper motor for the throttle body.
The cheapest way to rescue/ correct your car idling.
Interested!!! give me a call.
DDT
Central Region Contact h/p: 012-3223583 (Franky)
email: [email protected]
Or PM us & we will get back to you as soon as possible.
WhatsApp 012-3223583
DDT
********BUMP*******
DDT
DDT
********BUMP*******
DDT
DDT
********BUMP*******
DDT
DDT
********BUMP*******
DDT
DDT
********BUMP*******
DDT
DDT
********BUMP*******
DDT
DDT
********BUMP*******
DDT
DDT
********BUMP*******
DDT
DDT
********BUMP*******
DDT
DDT
********BUMP*******
DDT
DDT
********BUMP*******
DDT
DDT
********BUMP*******
DDT
DDT
********BUMP*******
DDT
DDT
********BUMP*******
DDT
civic EH5 (local model)
just noticed my PS fluid are low and found out that my tie rod have leaks. what are possible solution?
p/s: i've replaced whole steering rack less than 2y ago
another question from pic below... do i need to replace bush? (outer tie rod)
