Braking issue
lukel95
75
28
GB birmigham
Hi guys, recently if i full lock to the left and then brake whilst reversing my brakes make a very loud sort of trumpet sound, any ideas?
Sent from my SM-G935F using Tapatalk
crazykatak
776
48
Subang Jaya
might indicate a jammed brake piston or uneven rotor.
working the rear piston is such a hassle and takes alot of patience lol.
from your description, it sounds like it is not releasing fully or releasing too slow.
i had the same thing about 9 years ago..right after that, I found out that the rear brake was going to be jammed (after changing new pads).
try looking at 2 areas:
1. Rear brake caliper assy (pin, piston, pads, cables); check out the condition.
2. Rear brake rotors (uneven wear , warped)
good luck
lukel95
75
28
GB birmigham
good luck
Okay great thank you, I also hear a quiet scraping noise when I brake coming to a stop and especially going downhill the noise will continue after releasing the brake.
What should I look for in the caliper and what should I do?
Also can you tell if a rotor is warped?
Spin the disc and see how it turns. If warp, as it spins can see it wave left and right
My black Toyota Celica was stolen at the basement of my apartment at Ritze Perdana Damansara Perdana on the 23 April this yr. The thief actually broke the barrier and fled at 12.58 am. Apparently there were lots of such cases in this area.
