my boost Tee just serve a purpose as wastegate delay (the ballbearing-spring loaded port inside)
because if i leak air (to increase boost) using the boost Tee...straight away i'll get boost cut
plus...i'm using adjustable spring external wastegate....so just adjust boost direct at wastegate spring preload
better boost control this way (because already delete electronic boost solenoid)
