m3 power said:
my original rims is 155/55/R12 n now i'm using 165/45/R15. so how was that? how much cost to upgrade braking system? nid to change the whole system is it? from brake hose till rotor n brake pad?
oh my god thats big big difference. Did you recalibrate your speedometer? If not then when your speedo is doing 100km/h but actually you're doing 111km/h.
about the brakes, i personally won't say bigger rim must use bigger brakes, but instead its bigger rims CAN use bigger brakes. Well, i personally don't look into the asthetic side of the car, but just on the performance. Brakes' bigger the better until it is good enough to slow your car down. anything bigger will just make your car slow since brake rotor weight alot.
I personally would choose a rim to fit the brakes, instead of the other way around.
