I see, so the tacho in the middle is an optional item for the auto models.porosaki said:for auto unless u opt for the TRD meter cluster or the modellista ones,
cause they du have tacho in the middle for all altezza for all years.
Middle tacho only for manual version from may 2001 ~ 2005
For manual, Apexi RSM can remove the speed limiter. (only manual)ARSSS said:If I want to have my speed limiter removed what & where should I do it?
How fast U think in can go w/o speed cut?
Do you think stock 5 speed auto can get to 240kmh ?EventH said:If completely stock (final gear) ... max speed should be around 240km/h for the 6MT. (speed limiter removed)
for auto you can do it with sard attack meter but you might end up regreting. me and my fren done it to our auto before and end up some other problems coming out. Both having different problem but it works well with manual altezza.EventH said:For manual, Apexi RSM can remove the speed limiter. (only manual)
For auto, there is the SARD attack meter. Something like RSM but speed limiter removal also works with Auto.
Can you share what are some of the other problems coming out when using the Sard product?rinagi said:for auto you can do it with sard attack meter but you might end up regreting. me and my fren done it to our auto before and end up some other problems coming out. Both having different problem but it works well with manual altezza.
Recommended:
Manual - RSM, sard attack meter, hks sld type 1
Auto - SLD type 2
I think it doesn't works. Sherman and Steven still using the SLD type 2 for their Auto Altezza eventhough they installed F-Con SZ.EventH said:Can you share what are some of the other problems coming out when using the Sard product?
What about the F-con sz ... does the speed limiter removal works on altezza apart from tuning the car. If it works, then the whole package might be cheaper than getting a SLD type 2 + another piggyback.(I hope)
