Advice on major repair for e46
loose_end
3,649
197
Malaysia
Your oil seals cost a bomb,so does the simple valve cover gasket.
My mech just told me there are leaks through my valve cover gasket. How much should it be since 300 in this bill is a bomb. Thanks. Last I check online, some state 300+, some 170+
How about the Spark plug tube O-rings too.
Probably original is RM300 and aftermarket is RM170. Aftermarket if brand is not good, scare the oil will start to leak very fast, meaning cannot last long...:smokin:
gunnerzz
Jul 3, 2014
2,109
695
Melaka
I've worked on Renault F4p and Merc W124 engine before,the parts will be more expensive compared to jap car but BMW really at another level of expensive.
From experience,for valve cover or oil sump gasket it is safe to go for alternative part as not many lousy manufacturer will make part for expensive car due to low demand.
For oil seal,by allean go for oem part.
Above all,if budget not an issue then go for all OE part.
I've tried a replacement oil seal on my dpo gearbox before and it only lasted 1 day before atf came pouring out.
Change to OE part and problem solved.
loose_end
3,649
197
Malaysia
pac_jb, what was your symptom that needed top overhaul. Thx
wsonny
467
5,018
Ampang
Totally agree BMW car are high maintenance car, but when u driving it is totally difference feel. Hav to learn how to take care of her like ur wife. I cannot tahan mine ex E46 sold it oledi
I have 3 friends all sold theirs off, after their cars old and need plenty of repairs.....:bawling:
pac_jb
131
518
Just got my car, I totally got ripped better word to put is cheated, after one my coolant looks it's getting , when I add water the float stick will go down after few days, and when I told this to the workshop , they took the car and did pressure test and told everything is OK, when I ask back how come the coolant float stick can go down after few days ,they cannot answer, when I open the engine oil cap, I see inside , all brown color ,after overhaul should be cleaner , when I ask about this , they told they used chemical to clean but the dirt all hard to come off, and lastly at the head gasket the silicone sealant can be seen , normally when they put sealant at valve cover gasket ,you can see the sealant come out abit, but first time im seeing sealant at head gasket, and the thing annoyed me most was originally my valve cover looked very new, but when I got my car back , they painted the cover to black without asking me, the paint look cheap, when I ask they told the cover looked rusty that's why painted it to black ,speechless
pac_jb
131
518
I seriously didn't know, workshops like this really existed, their main goal is to cheat customer , and self proclaimed expert in European cars, and if you see their Facebook, they advertise their workshop through free nasi lemak and their so called woman mechanic, and they can put "we have shariah compliant(tutup aurat) and non-compliant(seksi) lady mechanics" , unfortunately I saw all this rubbish yesterday only, if I seen it earlier , I wouldn't have gone there, seriously regretting
marsha1l_v6
666
130
543
try file for tribunal if the workshop dont want to take responsible.:smokin:
btw, didnt notice you from seremban. i sent e36 usually at factory shoplot near the majistret court seremban. Specialize in only bmw, alot of owner dump 30k-50k for performance upgrade, especially e46.
You can sent there to justify the german garage work, whether they betul2 buat what they quote you on the bill
Hi there bros, i just bought a CAI from N1 and i wanted to install it on my Satria Gti. But i found out that there is not quite alot of space. I wanted the opening install on the spotlight hole.. anyone with gti bumper, can you teach me how to install them without flattening it? thanks dudes...!!
