4G92 low idle RPM after changing alternator
jebatdex
430
18
518
Skudai, Johor
Guys
I just had my alternator replaced. After that, I see my idle rpm is very low, around 500 (before this ok, around 1k). During alternator installation, I see the mechanic remove both terminals of the battery too.
Is it because of the ECU being reset? How to get it to normal idle rpm? Should I go to workshop, spend RM50 for them to properly set my ECU back (using that device which they plugged in it under the dashboard, I duno the name :confused:)? Appreciate all inputs. Thanks.
Beyond 20,000 RPM!
29,998
Guys
As far as I know that is only for diagnostic when engine check lights comes on, and not for tuning.
4G92 I think can tune idling if same as my 4G63. Just turn the screw on throttle body....
john_unai
371
80
528
mtkb
i thought OBD can adjust rpm, they just adjust the rpm reading on the the OBD..:questionmark::questionmark::questionmark:
jebatdex
430
18
518
Skudai, Johor
I think, i will clean the TB and see how. Is rpm still low, will adjust the screw on the TB a bit. Never touches that because before this, idle rpm is good. After remove the battery, ECU reset, than idle rpm drops.
Another question, on the TB, there is 3 vacuum hoses marked P E A. On mine, only P & E is connection, but A got nothing (no hoses connected to it). Is that normal?
Beyond 20,000 RPM!
29,998
I remember mine two are used and the one not used is plugged up with a cap
m a v [3] r i c k
9,000 RPM
9,074
27
Try driving your car around for 1 week or so and then see if it gets better. I don't know what is going on at the ECU but based on my personal experience, after a battery disconnection (change), my car will consume more petrol for the first tank and gets better eventually. Engine idling too will be affected.
I would say you should just drive your car as how you used to for a week or so before you waste any unnecessary money.
Beyond 20,000 RPM!
29,998
Means let the ecu learn back....:driver:
If that is the case, in future for any battery change, link a good battery on when removing old dead battery.....
jebatdex
430
18
518
Skudai, Johor
OK then... will do. Thanks :burnout:
jebatdex
430
18
518
Skudai, Johor
I cleaned the tb (as much as I can becoz I didnt take out the tb, just remove the plastic hose from the air intake), and I adjust the screw on the tb a bit, rotate counter clockwise about 100deg. Now, idle is fine. I dont know whether this will make my fc worse or not, since this is regard as manual setting, not computerized. Hopefully the fc is not much affected. I usually get 11cents/km for highway, and 14cents/km for urban driving, with current RM1.70/l fuel price. Lets see during this raya, will travel from Johor to Perak :burnout:
Beyond 20,000 RPM!
29,998
Should not affect your fc unless you tune idling very high and you idle most of the time in traffic....lol:biggrin:
Shinjite
864
120
Klang
OK then.. so I shouldn't be worried much. :proud: thanks
As long as your idling is all A-OK even with the air-conditioning turned on. Everything will be fine. Before going on a long trip back for Raya, do a regular service check up to make sure everything runs as intended :biggrin:
Beyond 20,000 RPM!
29,998
Mine the FICD a bit KO already, so without air con now higher a bit, then air con cut is just nice.....lol:biggrin:
The latest race series to partake in the GT Asia series, the Lotus Supercup Asia will also be entering the Malaysian Super Series (MSS) this year in October and November 2011, giving the national championship for circuit racing a timely lift in injecting a sense of excitement in the Malaysia motorsports scene.
‪GT4 at Sepang - Melia Kuala Lumpur...
