With F5M21 gearbox, using stock 175/70 R13 tyres will get you approximately 32km/h per 1000 rpm in 5th gear. You should see 120 km/h at around 3500 rpm.
Besides changing the final drive (which would cost a lot), you can try to upsize your tyre a little to increase the effective gear ratio. For instance, instead of a +2 upgrade to 195/50 R15, try 195/55 R15 instead. It will increase your ratio a bit, e.g. previously 3000 rpm at 5th gear will get your almost 100 km/h, now it will be a little over 100 km/h. If you try something larger like 205/50 R16, the increase will be more prominent - you'll be doing 110 km/h when your meter is reading around 103 km/h.
