3SGTE intake manifold mod
tom's
tom's
2,866
76
subang
www.zerotohundred.com
Found this pic in celica hyper rev.....quite useful.......they run a caldina ST215 3sgte intake manifold on ST205 3SGTE which is the same eng as MR2 245hp........the reason they used this is even air going in to each cyclinder....normally we experience piston blow from cyclinder 2 & 3
http://img34.imagefra.me/img/img34/2/8/18/toms/f_1nbdqh02lb3m_afdfd45.jpg
so i took the risk of buying the intake manifold to measure if it fit onto MR2/Celica 3SGTE eng without knowing if the intake will fit or not......brought back to my place today and took out original mr2/celica intake manifold gasket to measure
http://img32.imagefra.me/img/img32/2/8/18/toms/f_1nbdqh02lb3m_2b5f090.jpg
exact same fitting hole........so they money didn't go to waste.....hahaha.....next gonna measure the throttle body size......maybe need to mod a plate to mount the celica throttle.....
will update u guys....
khoo198
khoo198
1,917
2,067
N9
Similar tht means not confirm?? tom's...can u buy 1 n try the result for us??:rofl::rofl:
tom's
tom's
2,866
76
subang
why do u need st246 caldina i.manifold as the location of the throttle body same as mr2/celica..... if u want me to find out can......pass me RM1500 then i'll buy the caldina st246 i.manifold n try it out.....how deal khoo198??!??!?
khoo198
khoo198
1,917
2,067
N9
you prove it....i buy it...ngiahahh:rofl::rofl:
khoo198
khoo198
1,917
2,067
N9
very funny....dun ever look for me for any spare part.....ban u for real
Wah.....u look serious man.....joking only nia taikor...mayb wanto find some spare part frm u next time leyh..sparepart king.:wavey::wavey:
Green06
Green06
139
14
Pahang
Hi deblue, too expensive...........USD950.00 for the intake hdr. May be grp buy can nego.......will try to nego.:driver:
Green06
Green06
139
14
Pahang
This JUN replica intake if made to spec should flow more air not replacing TVIS. You can gut the TVIS. I did mine and it just act as an adapter plate now without throttle plates which aids better air flow. If you take a careful look at the manifold, TVIS assembly and the head all are misaligned by a couple of mm. You can mark them and grind them to align up the holes, that would give much better flow as steps causes air turbulence and that disrupt the air flow. You want a smooth flow of air into the combustion chamber.:biggrin:
EDDYSW20
EDDYSW20
114
20
Negeri Sembilan
Smooth & unrestricted flow I agree, just wondering what would the ECU think? I've been considering removing those butterflies, but did you note any difference at low idle or low rpm?
