A329878 said:
I'm planning to upgrade my ICE but the first question is what kind of amp should i put on ?
2 channel ,4 channel or 5 channel ?
I'm not the technol song mania ,i just want to setup a good sound system .:regular_smile:
Thank for input !
depend on the kind of setup that u want. Ask yourself first.
1. simple setup: 4 channel amp -> 2 channel to comp. set & the other 2 channel bridged to sub.
2. 2 x 2-channel amp -> 2 channel to comp. set & the other 2 channel amp bridged to sub.
3. 2-channel amp & mono amp -> 2 channel to comp. set & mono amp to sub.
4. Active setup using active xover: 1 x 4-channel amp & 2-channel bridged to sub.
5. Active setup using active xover: 1 x 4-channel amp & mono amp to sub.
6. Active setup using active xover: 2 2-channel amps (each for mid & tweet) & 2-channel bridged to sub.
6. Active setup using active xover: 2 2-channel amps (each for mid & tweet) & mono amp to sub.
plenty of variations. So it is up to you.
