Useful tip:Blinking AirBag Light @ Dash
hansc
490
30
3,028
KL/WP
hi all,
i was swapping my newly rewrapped steering 2 days ago... and to my horror, the Air Bag light at the dash suddenly came up blinking... checked every single connection and i am very sure i didnt break anything (just swapping steerings!!)....
ran a search online, found out that i need to reset the bloody Air Bag light.... simple steps:
1. turn your key to ON position (do not start your car)
2. immediately, press and let go the driver door switch 7 times within 10 seconds
3. the airbag light will go off
4. then start your car - the blinking light is gone!
nearly gotta fork out some money for diagnose with consult machine... hahahah....luckily its free!
hope this helps!
kethon27
80
hi all,
hope this helps!
Hi.. what do you mean "press and let go the driver door switch" ?
Press what?
Which door switch?
Is this applicable to all cars or only certain specific car only?
swift2510
66
13
Different car brand has different reset sequence. You have to be specific which brand are you referring to for your tips to be useful. I guess Nissan or maybe Renault?
BNR
144
21
Press what?
Which door switch?
Switch: the button that sense whether your car door is open or close.
hansc
490
30
3,028
KL/WP
Press what?
Which door switch?
It's the small black one on ur car frame. Usually it will switch off ur car room light when it's pressed.
---------- Post added at 10:10 PM ---------- 6 hour anti-bump limit - Previous post was at 10:09 PM ----------
This is a skyline forum. Therefore u won't be expecting me to talk abt Renault kangoo rite?
hansc
490
30
3,028
KL/WP
u must be swapping the steering without removing the negative battery terminal :) thats y the light will blinking
u r lucky because the airbag didnt deployed
Since when swapping steering will deploy the airbag? The impact sensors are located at the engine bay and frame, not in the steering.... :rofl:
huakenny
LB Performance
9,126
240
Kota Kinabalu
not necessary is skyline....im talking bout other car.
and for safety, always disconnect negative battery terminal.im just giving friendly advise
im working in this industry, im know what im talking
u laugh because u never experiece yet
even the impact sensors are destroyed during accident, it doesnt mean the airbag will deployed too :)
reintel
732
30
3,028
Trust me, this guy knows what he is talking!..
wuzzles
150
45
3,028
Totally Agree with huakenny... any mechanic, tint shop, aircond speacialist who is worth his salt will ALWAYS disconnect the terminal when doing any work around the dashboard - aircond servicing (if have to remove dash), ICE, doors, Tint (for those that have side air bags) etc.. Not paranoia, it is about doing the right thing.
The impact sensor is to send an electric signal to deploy and not the deployment agent itself. When car manu. test air bags, they don't keep wrecking a car to see if the bag will deploy. They only send the signal up the processor. Only when they test overall car, will they do an impact test.
So, any "miss" signal will deploy the bag into your face... better to be safe than sorry :)
Happy New Year, guys!
ahle@
1,102
12
malaysia
bro,how about if my car airbag have been deployed,then after change airbag,can i just plug and play install to the car?or i need to reset the airbag ECU?....(i worry the airbag ECU is in "deployed mode"...)
V-Spec
1,861
170
5,163
AFAIK, you'll need to replace the airbag control unit.
huakenny
LB Performance
9,126
240
Kota Kinabalu
u will need to replaced the said SRS Control Module or reflash it.
or i can reflash the SRS Control module at few hundreds. depending on car model. pm me
during airbag deployment :-
u need to replace
1.steering coupling
2.steering airbag (or any airbag that deployed)
3. safety belt(depend car model)
4.SRS ECU
V-Spec
1,861
170
5,163
If it's a GTT, I have the airbags + airbag control unit as spare. Should anyone need it la.
owtaman
107
Damn I should have found this info earlier, my airbag light came up a few months ago, I disconnect the wiring to the passenger airbag and removed the airbag bulb from the meter cluster.
BTW, where can I find the airbag control unit in a ECR33-S2 ? Maybe I should remove it as well to save weight, haha.. would it cause any trouble given there is no Airbags actually connected ?
I think some of you have already installed a pc in your rides. But i really need some idea as i got a spare old pc laying around and hope i could run it in my kenari and probably add in a 14" LCD and run Wifi or watch DVD .
Its an old P3 600mhz with 256mb ram,onboard sound (creative) and agp card with tv-out.
The board is smaller then mATX .
The main thing is LOW COST DIY.
So, the problem would only be the expensive LCD monitor and how to mount it. Any one have an idea on how or where...
