Perdana V6 Gearbox Problem
nameejokerx
Aug 3, 2013
50
508
yep. more like a rm550 shirt..
but its a "keperluan", no gearbox, cannot move.
so have to spend the money.
not like u, buy e-manage, thats a "kemahuan".
duit byk, everything also have.
:thefinger:
Haha. Just booked only.
Need to see how overhaul going.
If got extra backup from MJ sure dyno.:burnout:
Hahaha.
civic1533
851
yep, for V6 better go rebuild the gbox.
for me, gbox also kong last week, but RVR engine, so i bought 2nd hand gbox je la..
hi bro, need some help here. know that ur using rvr auto same as mine. few month back my gb kong also. found 2nd hand rs rvr gb and since then im having this mounting issue. the mech couldnt find the same mounting for the gb, so he modified the mount and now weird noise came out. what type of mount to use?
NeuroOne
WFH
2,074
181
Putrajaya
which mounting bracket is it?
my front use v6, left use rvr, right use v6/sei (cant remember), rear is custom made with thick steel, made to look like ori.
civic1533
851
the gb side and front that always kong. custom made with thick steel only, no rubber? any vibration?
NeuroOne
WFH
2,074
181
Putrajaya
no no. the 'mounting bracket' is custom made (from gbox to mounting point).
the mounting rubber still the same and at the same mounting point.
if ur mounting always koyak, maybe ur engine is senget.
or u can try putting full rubber or pu mounting.
civic1533
851
ill try the v6 mount for front, suspect he use sei mount that cant support the heavy engine & 4wd gb. ur left rvr mount bought brand new or h/cut ?
NeuroOne
WFH
2,074
181
Putrajaya
emmm, let me clarify a bit more:
- the front mounting bracket is from the RVR engine.
- the right-side mounting bracket (on top of gbox) is from SEI (i think, can exactly remember if its SEI/V6 coz never open/change it since i transplanted the engine 3 years ago).
- the rear mounting bracket (from gbox to rubber mount) is custom made.
- the rubber mountings for all 3 mounting points are from V6.
- the left-side mounting is from the RVR engine itself.
u can buy a full rubber mount to make it tougher and longer lasting.
my front and rear rubber mountings are full rubber.
u have to check also if your engine is aligned properly.
if the engine is tilted (senget) then it may effect the rubber mount to worn out earlier.
civic1533
851
im confused here. u change the inside rubber to v6 rubber? done all this at najib place?
NeuroOne
WFH
2,074
181
Putrajaya
ok ok sori sori. i give picture la easier..
this is example of mounting (rubber mounting)
front, rear and right side.
this is what i mean for mounting bracket.
this example for right-side (gbox) and rear (gbox)
civic1533
851
arrr... now i understand. the rubber mounting is what im referring to. so ur gb rubber mounting is from v6?
The highly popular 1,5L Vios has been facelifted for 2021 and is set to arrive with a new sportier face and a range of new safety features. Bookings are now open and will begin now via online and the dealerships. The newly enhanced Vios, with its Toyota Safety Sense (TSS) that includes pre-collision system (PCS) and lane departure alert (LDA) earn it a 5-start ASEAN NCAP safety rating...
