Honda Engine Codes (revised)
doppelganger
doppelganger
296
11
Hi all ppl & sifuu's :wavey:. I know that a similar thread was created sometime in 2005, but the TS didn't update it after that. Im just 'passionately curious' (borrow from Einstein words :smokin:) about facts.
The list below was written by mahBLACKaccord from usa in www.accordracing.com
Engine Codes / Size / Type / Vehicle & Power Ratings
EW4 1.4L & 1.5L SOHC PGM-Fi '84-'87 Civic 60-92hp
D15B 1.5L SOHC non-VTEC '88-'95 Civic's 62-102hp
D16A1 1.6 L DOHC 86-89 Integra 86/87 113hp 88/89 118hp
D16A6 1.6L SOHC 88-91 Civic Si/ CRX Si 108hp
ZC JDM equivalent of D16A1 130ps
D16Z6 1.6L SOHC VTEC 92-95 Civic EX/Si 125hp
D16Y5 1.6L SOHC VTEC-E 96-00 Civic HX 115hp
D16Y7 1.6L SOHC non-VTEC 96+ Civic CX/DX/LX 106hp
D16Y8 1.6L SOHC VTEC 96+ Civic EX 127hp
B16A 1.6L JDM DOHC VTEC 89-91 Civic Si-R I/CRX Si-R, Integra RSi/XSi 160ps
B16A2/3 1.6L USDM DOHC VTEC 93-97 DelSol VTEC/99-00 Civic Si 160hp
B16A 1.6L JDM DOHC VTEC 92-95 Civic Si-R II/ 92-97 CRX DelSol SiR 170ps
B16B 1.6L JDM DOHC VTEC 98+ Civic Type R 185ps
D17A2 1.7L SOHC VTEC-E 01 Civic EX 127hp
D17A1 1.7L SOHC non-VTEC '01+ Civic DX/LX 115hp
B17A1 1.7L USDM DOHC VTEC 92-93 Integra GS-R 160hp
B18A1 1.8L USDM DOHC non-VTEC 90-93 Integra RS/LS/GS 90-91: 130hp / 92-93: 140hp
B18B1 1.8L USDM DOHC non-VTEC 94-01 Integra RS/LS/GS 140hp
B18C 1.8L JDM DOHC VTEC 94+ Integra SiR-G 180ps
B18C1 1.8L USDM DOHC VTEC 94+ Integra GS-R 170hp
B18C5 1.8L USDM DOHC VTEC 97+ Integra Type R 195hp
B18C6/7 1.8L JDM DOHC VTEC 96+ Integra Type R 200ps
B20A5 2.0L DOHC non-VTEC 87-91 Prelude 2.0Si 135hp
B20B 2.0L DOHC non-VTEC 96-98 CR-V 126hp
B20Z 2.0L DOHC non-VTEC 99-01 CR-V 143hp
B21A1 2.1L DOHC non-VTEC 90-91 Prelude Si 145hp
K24A4 - 2.4L DOHC i-VTEC - 2003+ Accord
K24A4 - 2.4L SOHC i-VTEC - 2004+ Acura TSX, Honda Element,2004+ Accord (JDM)
K20A3 2.0L DOHC i-VTEC '02+ RSX 02+ Civic Si 160hp
K20A2 2.0L DOHC i-VTEC 02+ RSX Type S 02+ Civic TypeR 200hp
K20A 2.0L JDM DOHC i-VTEC '02+ Integra Type R 220ps
F20A1 2.0L JDM DOHC non-VTEC 90-93 Accord Si 155hp
F20B 2.0L JDM DOHC VTEC 90-93 Accord Si-R 190ps
F20C1 2.0L DOHC VTEC '00+ S2000 250ps/240hp
F22A1 2.2L USDM non-VTEC 92-96 Prelude S 90-93 Accord LX/EX 130hp-135hp
F22B 2.2L USDM SOHC VTEC 94-97 Accord EX/97 2.2CL 145hp
F23A5 2.3L USDM SOHC 98+ Accord DX 135hp
F23A1 2.3L USDM SOHC VTEC 98+ Accord EX & LX/98-99 2.3CL 150hp
F23A4 2.3L USDM SOHC ULEV VTEC 98+ Accord EX & LX 148hp
H22A1 2.2L USDM DOHC VTEC 92-96 Prelude VTEC 190hp
H22A4 2.2L DOHC VTEC 97-01 Prelude VTEC/SH 97-98: 195hp 99-01: 200hp
H22A 2.2L JDM DOHC VTEC 92+ Prelude Type-S, 97+ Prelude SiRS Spec 220ps
H23A1 2.3L USDM DOHC non-VTEC Prelude Si 160hp
G25A1 2.5L USDM SOHC non-VTEC 96-98 2.5TL 176hp
J25A 2.5L JDM SOHC VTEC V6 JDM Honda Aspire/Sabre 200ps
C27?? 2.7L USDM SOHC non-VTEC V6 86-89 Legend 150-160hp NEED HELP ON THIS
C27?? 2.7L USDM SOHC non-VTEC V6 95-97 Accord V6 170HP NEED HELP ON THIS
C30A(?) 3.0L DOHC VTEC V6 91-96 NSX/NSX-T 270hp NEED HELP ON THIS
J30A1 3.0L USDM SOHC VTEC V6 98-02 Accord V6/97-99 3.2CL 200hp
C32A6 3.2L USDM SOHC non-VTEC V6 91-95 Legend Sdn, 91-92 Legend Cpe 96-98 3.2TL 200hp
C32A5 3.2L USDM SOHC non-VTEC V6 94-95 Legend GS Sdn, 93-95 Legend Cpe 230hp
C32A? 3.2L DOHC VTEC- V6 97+ NSX/NSX-T 290hp NEED HELP ON THIS
J30A4 - 3.0L SOHC VTEC V6 - 2003+ Accord
J30A - 3.0L i-VTEC - 2003+ Honda Inspire (JDM)
J32A1 3.2L USDM SOHC VTEC V6 98+ 3.2TL/3.2CL 225hp
J32A2 3.2L USDM SOHC VTEC V6 00+ 3.2CL Type-S, 01 3.2TL Type-S 260hp
J32A3 Acura TL 2004+ 3.2L V6 (201 kW) 270 HP SAE @ 6,200 rpm; 238 ft lb , 323 Nm @ 5,000 rpm
C35A2 3.5L USDM SOHC non-VTEC V6 3.5RL 215-225hp
J35A1 3.5L USDM SOHC VTEC V6 98+ Odyessy 210hp
J35A3 3.5L USDM SOHC VTEC V6 Acura MDX 240hp
To mods, i'll remove this thread if it shoudnt be here. To all its not complete. yet.
Bump: Below is a listing of Generation 4 Honda Accord and Generation 3 Honda Prelude F22 Type engines.
F22A1: 1990-1993 Accord, 2.2 liter (2156 cm³), MPFI fuel system, 125 hp (93 kW) @ 5200 rpm, 137 lbf·ft (186 N·m) @ 4000 rpm, 8.8:1 compression, oil pressure 50 psi (340 kPa) @ 3000 rpm.
F22A4: 1990-1991 Accord, 2.2 liter (2156 cm³), MPFI fuel system, 130 hp (97 kW) @ 5200 rpm, 142 lbf·ft (193 N·m) @ 4000 rpm, 8.8:1 compression, oil pressure 50 psi (340 kPa) @ 3000 rpm.
F22A6 1990-1993 Accord, 2.2 liter (2156 cm³), MPFI fuel system, 140 hp (104 kW) @ 5600 rpm, 142 lbf·ft (193 N·m) @ 4500 rpm, 8.8:1 compression, oil pressure 50 psi (340 kPa) @ 3000 rpm.
The following list of F22B Engines are [VTEC] and [NON-VTEC] SOHC Engines found in the 1994-1997 Honda Accord, 1995-1997 Honda Odyssey, and 1997 Acura CL.
F22B1 1994-1997 VTEC Accord EX, 1997 CL, 2.2 liter (2156 cm³), MPFI fuel system, 145 hp (108 kW) @ 5500 rpm, 147 lbf·ft (199 N·m) @ 4500 rpm, 8.8:1 compression, oil pressure 50 psi (340 kPa) @ 3000 rpm.
F22B2 1994-1997 Non-VTEC Accord LX, DX, SE, 2.2 liter (2156 cm³), MPFI fuel system, 130 hp (97 kW) @ 5300 rpm, 139 lbf·ft (188 N·m) @ 4200 rpm, 8.8:1 compression, oil pressure 50 psi (340 kPa) @ 3000 rpm.
F22Z2 1996-1998 VTEC Accord (Euro), 2.2 liter (2156 cm³), MPFI fuel system, 150 hp @ 5500 rpm, ??lbf·ft (??N·m) @ 4500 rpm, 9.3:1 compression. NEED HELP ON THIS
F22B6 1995-1997 VTEC Odyssey, 2.2 liter (2156 cm³), MPFI fuel system, 145 hp (108 kW) @ 5500 rpm, 147 lbf·ft (199 N·m) @ 4500 rpm, 8.8:1 compression, oil pressure 50 psi (340 kPa) @ 3000 rpm.
bien335
bien335
1,819
48
Johor Bahru
most of the engine codes are unique, USDM/EDM motors, since they have the numerical suffix (F22a6 etc..)
JDM Motors dont have these suffixes (as far as the H,K and F-series are concerned)
the suffixes denote a variant within the engine family itself, which might have a different state of tune.
for instance, the JDM F20B motor could either be the SOHC non-VTEC F20B in the CD4, the SOHC VTEC in the CF4/CF5, the DOHC VTEC 180PS SiR, or DOHC VTEC 200PS SiR-T.
the same applies for the H22a. JDM H22as were fitted in the Accord and prelude, with 3 state of tune, 190PS, 200PS and 220PS, but all three are H22A.
For the USDM market, the CB7 had 3 different F22a motors, the base F22a1, F22a4 and F22a6, all three having different power ratings by the use of different cams, different ECU, different headers. But they were differentiated by the -a1, -a4 and -a6 suffix.
Europe also had a few H22as, namely the H22A7 in the Accord type R.
doppelganger
doppelganger
296
11
Thx for the info bien. Do you have any info for Fit/Jazz engine? i think they start with 'L' series but dunno wat the output is.
I thought id some more info i found.
Honda straight-4 engines
The number in the engine code gives the approximate displacement of the engine. e.g. B18A would have an approximate displacement of 1.8L, H22A1 would have an approximate displacement of 2.2L.
The letters/colours at the end of the line represent the market where the car was sold:
o USDM = United States Domestic Market
o JDM = Japanese Domestic Market
o EDM = European Domestic Market
Year/ Code/ Type/ Displacement (cc)
* A-series
o 86+ A16A1 Accord 1.6 EDM
o 84-87 A18A1 Prelude USDM
o 85-89 A20 Accord EFI EDM
o 86+ A20A1 Accord 2.0 EX EDM
o 86+ A20A2 Accord 2.0 EX EDM
o 88-89 A20A3 Accord USDM
o 86+ A20A4 Accord 2.0 EXi
* B-series
o 1996 B15 1.5 L (Honda City - Asia) SOHC VTEC and SOHC non-VTEC
o 89-92 B16A Civic SiR JDM
o 90-93 B16A Integra RSi/XSi JDM
o 92-95 B16A Civic SiR II JDM
o 89-92 B16A1 Civic VT EDM
o 90-91 B16A1 Civic SiR JDM
o 91-95 B16A2 Civic Vti EDM
o 99-00 B16A2 Civic Si USDM
o 94-97 B16A3 Del Sol VTEC USDM
o 94-97 B16A3 Del Sol Vti-T EDM
o 96-00 B16A4 Civic SiR II JDM
o 97-01 B16B Civic Type-R JDM
o 92-93 B171 Integra GS-R USDM
o 90-91 B18A1 Integra GS USDM
o 92-93 B18A1 Integra GS USDM
o 94-95 B18B1 Integra USDM
o 96-00 B18B1 Integra USDM
o 95-97 B18C Integra GS-R JDM
o 96-00 B18C Integra Type R JDM
o 94-00 B18C1 Integra GS-R USDM
o 95-9 B18C3 Integra Type R JDM
o 97+ B18C4 Civic 1.8 Vti EDM
o 97;98;00 B18C5 Integra Type R USDM
o 96+ B18C6 Integra Type R JDM
o 96+ B18C7 Integra Type R JDM
o 87-89 B20 Accord 2.0i EDM
o 85-87 B20A1 Prelude Fi EDM
o 86+ B20A1 Prelude 2.0i EDM
o 87+ B20A2 Accord 2.0i EX EDM
o 90-91 B20A3 Prelude 2.0 S USDM
o 88+ B20A4 Prelude 2.0
o 90-91 B20A5 Prelude 2.0 Si USDM
o 88-89 B20A5 Prelude Si USDM
o 87-92 B20A7 Prelude 2.0i EDM
o 88+ B20A8 Accord 2.0i EDM
o 87-92 B20A9 Prelude 4WS 2.0i EDM
o 97-98 B20B CR-V USDM
o 97+ B20B3 CR-V RD1 EDM
o 97-98 B20B4 CR-V
o B20Z SMX JDM
o 90-91 B21A1 Prelude Si USDM
Year/ Displacement (cc)/ Code/ (Type)
* D-series
o 1991 1.4 L D14 (Civic)
o 1993 1.5 L D15b2 (Civic) VTEC-E
o 1993 1.6 L D16 (Civic/Integra) VTEC-E/VTEC-II
o 2001 1.7 L D17 (Civic) VTEC-E/VTEC-II
* E-series
o 1973 1.2 L EB (Civic)
o 1975 1.5 L ED (Civic) CVCC
o 1976 1.6 L EF (Accord)
o 1980 1.3 L EJ (Civic)
o 1979 1.8 L EK (Accord/Prelude)
o 1980 1.5 L EM (Civic) CVCC
o 1984 1.4-1.5 L EW4 (Civic)
o 1983 1.8 L ES (Accord/Prelude)
o 1985 1.8 L ET (Prelude)
o 1984 1.3 L EV (Civic)
o 1984 1.5 L EW (Civic/CRX)
* F-series
o 1988 2.0 L F20 (Accord) VTEC
o 1990 2.2 L F22 (Accord/Prelude/CL) VTEC & Non-VTEC
o 1998 2.3 L F23 (Accord/CL) VTEC
* F20C
o 2000 2.0 L F20C (S2000) VTEC
Year/ Displacement (cc)/Code/ (Type)
* G-series
o 1996 2.5 L G25 (TL)
* H-series
o 92-96 H22 Prelude VTEC JDM
o 94-97 H22A Accord SiR JDM
o 97-01 H22A Prelude SiR JDM
o 97-01 H22A Prelude Type S JDM
o 97-98 H22A1 Prelude USDM
o 93-96 H22A1 Prelude VTEC USDM
o 94-96 H22A2 Prelude 2.2i EDM
o 99-01 H22A4 Prelude SH USDM
o H22A5 Prelude EDM
o 97-01 H22A7 Accord Type R JDM
o 93-95 H23 Prelude Type S JDM
o 92-96 H23A1 Prelude Si; SE USDM
o 92-96 H23A2 Prelude/Accord 2.3i EDM
o 93+ H23A3 Accord 2.3l EDM
Year/ Displacement (cc)/ Code/ Type
* J-series
o 1998 1.6 L J (HR-V)
o 1998 1.6 L JS (HR-V)
o 2001 1.6 L JS4 (HR-V) VTEC
* K-series
o (03+) 01+ K20A Integra TYPE-R; Civic TYPE-R; Accord Euro R JDM
o 01+ K20A2 RSX Type S USDM
o 01+ K20A3 Integra IS JDM
o 01+ K20A3 RSX Base, Civic Si USDM
o 03+ K24A Accord; Accord Wagon JDM
o 03+ K24A2 TSX 200 USDM
o (03+) 02+ K24A3 CRV; Element; Accord
* L-series
o 2001 1.3 L L13A (Fit/Jazz) - engine marketed as 1.4L in certain regions
o 2002 1.2 L L12A (Jazz)
o 2002 1.5 L L15A (Fit/Fit Aria/Airwave/Mobilio)
* Circle L - General Motors/Isuzu 1.7 L Diesel
* R-series
o 2006 1.8 L R18A1 (Honda Civic) i-VTEC
Honda V6 engines
* C-series - 90° SOHC/DOHC
o 1985 2.0 L C20 (Honda Legend)
o 1986 2.7 L C27 (Legend/Accord)
o 1991 3.0 L C30 (NSX)
o 1991 3.2 L C32 (Legend/TL/NSX)
o 3.5 L C35 (RL)
* J-series - 60° SOHC
o 2.5 L J25 (Inspire/Saber)
o 3.0 L J30 (Accord/CL)
o 3.2 L J32 (TL/CL)
o 3.5 L J35 (Odyssey/MDX)
bien335
bien335
1,819
48
Johor Bahru
You're welcome.
I'm not too sure about the L-series.. need to go and pop the bonnet of the City, but it's raining LOL. L15A2 i think for the I-DSi, not sure if the VTEC shares the same code as well.
As for the F-series, here's a quick list of the JDM/USD/EDM engines. (I get confused with the USDM/EDM numerical suffix)
OBD-I
F18A SOHC PGM-Carb - 105PS @ somewhere around 6000rpm (tak ingat), 143Nm
F20A SOHC PGM-Carb - 110PS, 160-ish Nm
F20A SOHC PGM-Fi - 133PS, 180-ish Nm
F20A DOHC PGM-Fi - 150PS, 187 Nm
F22A SOHC PGM-Fi (JDM) - 140PS, 193Nm
F22A1 (USDM) - 125hp, 180-ish Nm
F22A4 (USDM) - 130hp, 193Nm
F22A6 (USDM) - 140hp, 193Nm
F22A7 (EDM, Aus) - 140/150hp, 200Nm (reference needed)
F18B SOHC - 125PS, 165Nm
F20B SOHC - 135PS, 181Nm
F22B SOHC VTEC - 145PS, 200Nm
OBD-II
F18B SOHC VTEC (JDM/EDM) - 140PS, 165Nm
F20B SOHC VTEC (JDM/EDM) - 150PS, 186Nm
F20B DOHC VTEC (JDM) - 180PS, 186Nm (SiR)
- 200PS, 200Nm (SiR-T)
F23A SOHC VTEC (JDM) - 150PS, 206Nm
F23A1 (USDM)
F23A5 (USDM) - 135hp, 206Nm
I'll continue with the H-series when I get back home
:D
doppelganger
doppelganger
296
11
Hi, Can you tell me what is VTEC-E & VTEC-II... Is there any difference between I-VTEC..
doppelganger
doppelganger
296
11
what engine is the stream rsz & odyssey absolute using? since both are in the same price bracket...
bien335
bien335
1,819
48
Johor Bahru
The RB1 Odyssey Absolute is using the K24A, while the Stream RSZ uses an R18A and an R20A.
The non-Absolute Ody uses a K24A as well, but with less power and torque.
freeman1314
freeman1314
203
Why does my engine reads ME516 ? Chasis code starts with EH5. It's a 1995 civic eg 3 door.
Been trying to look for details about this engine but no luck.
Bump: Why does my engine reads ME516 ? Chasis code starts with EH5. It's a 1995 civic eg 3 door.
bien335
bien335
1,819
48
Johor Bahru
it's a localised D16.
malaysian assembled Hondas (during kah motor era) had their motors start with M. ME, MA etc..
Hey I've seen there's some great information on here so I thought I'd run my project past the forums to make sure it's correctly planned out.
Like the title says, I'm planning to modify a 1994 Lancer very soon. The 1st thing I want to do is transplant a 4g93 under the hood for extra horses and reliability down the line when I want to turbo.
Will a DOHC MPI or GDI mount straight into the engine bay or am I looking at modifying the mountings?
Also will I need to tune a new ECU for it...
