Help!!
fokyerdoder84
126
johor
to all sifus...currently i had 2 issues:
1) after installing the power fc(L-jetro), the engine check light came up but i didnt feel anything wrong with my car....anyone had this kind of thingy b4?? n wht the solution?? i've brought her to 1 of the workshop in sunway but unfortunately they asked for the standard ECU for diagnose which i've lost:bawling:
2)the idling is currently picking up n down(from 700rpm-1200rpm) continuously n it sounds like an idiot which really annoying me...i've asked around n some said that the idling valve 'fucked up' n need to be replaced....anyone had this problem b4?? pls help me brosss...
p/s:im using er34 with some light mods.
thanks in advance!!cheers!!
V-Spec
1,861
170
5,163
Does the serial number the Power FC ends with 0030?
V-Spec
1,861
170
5,163
Check yours first bro.
fokyerdoder84
126
johor
orite...im out of the shore atm...will get back to u guys once i've check it..many thanks..
BNR
144
21
For the engine check light, since u say nothing wrong with the car, could it be u did not switch off the boost reading from ur FC Commander? Because u may not have the Apexi solenoid to read boost to ur PFC.
As for the unusual idling, it could b due to many reason... Better ask around others workshops.
MrNismo
590
65
5,028
Check engine light on most likely because boost control option is set to on. On certain models engine will die off, for RB25 it won't.
Erractic idling could be due to your Power FC did not go through idling initialisation learning. You need to reset it, and when you first turn it on, let the car idle 5 minutes without air-cond, then another 5 minutes with air-cond. If this doesn't do the trick, then most probably your AAC valve is dirty and requires cleaning.
fokyerdoder84
126
johor
thanks for ur info bro...will check it out
---------- Post added at 03:53 PM ---------- 6 hour anti-bump limit - Previous post was at 03:45 PM ----------
Thanks a lot for the advices..BTW AAC valve=Idling valve isn't it?? n any suggestion which w.shop could solve those problems....
im living around jb,but so far i dont find any good reliable mechs here especially on electronic parts.
bnr_32
568
36
3,028
JOHOR BAHRU
u r in jb? pm me bro.. need tu kumpul all skyliners from jb :biggrin:
fokyerdoder84
126
johor
yes bro...which area r u?? heard abt few skylines playing around jb but i nvr meet them..
hye again, does any1 know or experience the zerone adjustable suspension,
does it to bumpy? or just nice? actually, im planing to buy soon, i really need ur advice?
prefer hi,lo,so,hard........ my budget is around rm2k.
pls advice,tq.
