engine hard to start when its hot
Feb 6, 2013
i kena like this oledi. to the best of my experiences, its a sign of the headgasket is failling.. compression loss when ur temps up then the cyld head bengkok abit making all the valve seated improperly and maybe ur block or piston kembang. go for compression test.. when its hot ur piston jammed a bit leh.. give a moment then it'll crank.. check then if its running idle.. are u toping up water to ur radtor?
Rleo6965
161
46
528
Philippines
If you can hear starter solenoid clicking but crankshaft does not rotate. Possible dirty carbon contacts on starter and will cause weak torque. Hot engine harder for the starter to rotate the crankshaft.
civic1533
851
what about the fuel smell? having the same problem, still not solved. juz let the engine running with my turbo timer.
Want to be among the first to own the Toyota 86? Well, better put down your orders down now as the bookings for the Subaru BRZ’s twin is now open! According to the indicative on-the-road price released by UWM Toyota Motor, the 2.0l FR machine’s price will be at RM 243,000 for the manual transmission, and an extra RM 6,000 if one fancies the automatic. But there’s no further word yet on whether there are any...
