My transmission has a slight slip only from gear 2 to 3. Does not always happen. Normally it stop slipping when I turn off engine and start it again and it shifts smoothly. Replaced my atf fluid with nissan d magtic (been using since day 1) my mech said my old fluid was normal and not too dirty. Did some research and many stated the culprit is the speed sensor.. replaced that but problem still occurs. I really think its an electronic issue not a mechanical. No error code on the diagnostics btw. Planning to send to SC and see if they might have a solution. My mech said could be a mechanical problem though. It will not slip if I shift from 2 to D or if medium or hard throttle. Only on very light throttle and not very often
https://www.youtube.com/watch?v=IzRuxtSHN6M&feature=youtube_gdata_player
