Hey2...guys...
There is 4 type of air suspension kit that we can play with.
1st type: Basic Air Suspension Kit
* This is a complete kit with the most excellent dampening setting to match up properties of pneumatic springs in order to increase the vehicle’s stability, unlike other brands come with non adjustable shock absorbers which causes the vehicle to be bouncy and unstable during cornering. Modifying upper mount, cutting car body or welding the OEM shock to the vehicle is not required when our kit is fitted to the vehicle unlike other brands.
* Not only is this system allowed to change air pressure, but you can also adjust the maximum and minimum ride height freely to match up a body kit to get the desired ride height, which is one of our products features that other brands do not have.
* This product includes a full set of shock absorbers. It is at your option to replace air bags with 4 x coil springs to make a full set of shock absorbers once an air management system is not fitted. (PS. The high performance shock absorbers supplied with this kit are dampening and ride height adjustable).
* This system is designed for easy bolt-on, it not required to work with the O.E.M shock absorbers unlike other brands.
* This system has 36 levels of adjustable dampening, ride height adjustable, including upper mount in the fronts and rears. The McPherson strut comes with pillow ball top mounts to have ability to adjust the camber degree.
* You can choose the types of top mounts freely such as pillow ball top mount, aluminum top mount, rubber top mount, and rubber with pillowball top mount.
* This system comes with a high-pressure, mute and rotational speed compressor from a famous brand called AZ. The speed of pumping the airbag is the fastest in the world. It takes only 3.5 minutes for 2 compressors to pump a 20L tank 0~200psi. Unlike other brands plates make such a loud noise, each compressor comes with 4 snubbers and high-tech silencers to decrease noise suppression.
* Also, a tire pressure gauge can be connected to the air tank to fill your tires; the air pressure in the tank is sufficient for the tire pressure gauge.
* A pneumatic tool can be connected to the air tank as well to clean the exterior of your vehicle, the air pressure in the air tank is sufficient for the pneumatic tool.
* You can adjust the ride height with such ease while in the car. The ride height can be adjusted all the time to reach your desired height depending on the load of your vehicle.
* A pressure gauge supplied with this kit shows the vehicle ride height. Adjusting the vehicle ride height is allowed when the vehicle is in motion.
* The adjustment range of ride height is between 0 – 120/200mm. (based on different applications)
* The speed of lowering and raising vehicle ride height is 4-7 seconds only.
THIS SYSTEM INCLUDES
* 5 GALLANT AIR TANK 1/4 PORT × 2 , 3/8 PORT × 2
* AZ OB2 HIGH SPEED COMPRESSOR × 1
* SNUBBER FOR MOTOR USE × 4
* HIGH PRESSURE HOSE FOR MOTOR USE × 1
* HIGH-TECH SILENCERS PLATE BASE × 1
* 120 - 150 PSI PRESSURE SWTTCH × 1
* PADDLE VALVE SWTTCH × 2
* 200 PSI DUAL NEEDLE GAUGE × 1
* PADDLE VALVE SWITCH AND GAUGE BRACKET × 1
* 35M 1/4 AIR LINE × 1
* 5M POWER CORD × 1
* 100A FUSE × 1 , FUSE BOX × 1
* COOPER JOIN × 1
* SHOCK ABSORBERS (INCLUDING TOP MOUNT, SHOCK BODY) WITH 36 LEVELS OF ADJUSTABLE DAMPENING × 4
* AIR BAG × 4
* MANAUL INSTALLATION × 1
