- Apr 22, 2005
- 1,141
- 14
- 5,138
This kind of problem , usually does not trigger an error code especially for our fatties(cefiros) , if any it would most likely read the knock sensor which i doubt is the cause. However, my best bet for your problem would b the maf as suggested by xtec, forget about cleaning the maf, do a switching test .That is, swap a working maf and see whether it fix the problem or not. Do not forget to reset ecu thereafter... let us know the outcome..update,
went to ecu scan and found no error code
:hmmmm:, what to do next? i'll start with cleaning AFM and iacv-aac and injectors...
gotta try it one-by-one with lotsa patience
