What's d standard B18CR on wheel HorsePower can get when dynorun?
deacon
Senior master debater
1,167
30
I didn't know it had anything to do with america. Bolt-ons are just general knowledge...
JINEIL2EN
Over 10,000 RPM!
15,317
525
Island Of Pearl
team99ers.2.forumer.com
ahaha... dunno la, cos i not general enuf kua... soli soli for my greenest...
if go most of workshop in sunway, said:" tauke, wa nak bolt-on...." i think the answer will b..": lu nak Taiwan 1 or lu mau TD04...."....
nvm, thanks for ur general information.
Thanks bro..:itsme:
akuma
3,489
152
Kuantan
Whr did u dyno ur car n wat type of dyno was used?different dyno will show different figures.
i assume u did ur run on a dynojet(whc is more popular here in M'sia),175whp & 17.59kgm of torque if u ask me is a lil on d low side.......
if i remember correctly,my old B16B w stock cams registered 171whp & 17.01kgm of torque w VAFC in JC Racing Asia......150mm HKS SPF,sum chapalang JDM 4-2-1 header(no brand 1) w 2.5" mild steel piping.........175whp shud b d power figure 4 a totally stock but healthy B18CR....
dis is my 2 kupang lar...
cheers
Just dyno my B18CR today.
Mine is B18CR with B16B cam. 2.3 piping with Mugen airbox & 5Zigen 4-2-1.
Got 175HP on wheel & torque is 17.59 on dynojet. Is this normal figure for my setup or way too low for B18CR with B16B cam?
Just want to know how big the difference between B18CR & B16B cam?
And also I have been advised not to use fully syntethic engine oil for VTEC & recommended to use semi-syntethic. What's all sifu comment?
Sil80-13
1,215
44
1,648
cheers
WAH. Which means my B18CR have something wrong with it. Either engine is not healty enough or my cam setting is not good enough. Damn...:bawling:
akuma
3,489
152
Kuantan
so i guess my assumption dat u did ur run on a Dynojet is correct then?but thn again,dun just look @ ur peak whp & torque...shud study d overall graph,whn ur power comes in n whn it tapers off....dis shud tell u in whc gear n wat rpm u can optimise ur car's useable power....a fren w a SKUNK-ed 2dr EG,same whp as me got whooped ass frm my car over 400m...whn i saw his dyno graph thn i know y...
n yes,d correct cam setting will gif sm nice whp gain too.....w my std CTR cams,i got 165whp...after setting it,i got 171whp...n even after switching to Toda B n setting it,i cud only gain another 2whp...whc means CTR cams do haf very lethal potential!
good luck in raising ur power level...
cheers
akuma
3,489
152
Kuantan
CTR cams do 200whp?can?but show me it's being done w 81mm pistons,i believe elephant can fly thn!hahahhaha......or,if can oso,it's more like a time bomb,right?hehehehehehhe
u got dat engine is it?come on,let us know d recipe!quick!
JINEIL2EN
Over 10,000 RPM!
15,317
525
Island Of Pearl
ur fren who doing 2:41min last sunday is stock B18CR cam only... doing 202whp ma... ahhahaha...
why time bomb..?? its more safer than putting hi-cam wat...:biggrin:
akuma
3,489
152
Kuantan
dat white EK?whr got stock B18CR cams?kenot b lar..he told u meh?i 4got his specs but i know is not stock Type R cams,nor is it running on stock Type R pistons..wooppss..u din hear dis frm me!hahahahahha
JINEIL2EN
Over 10,000 RPM!
15,317
525
Island Of Pearl
stock cam... very sure la...:biggrin:
the intake parts really makes huge difren...
lwk2047
77
my set up is like tis b16b head wit sk2 tunner3 cam set,sk2 intake manifold,s90 tb,b18c block wit wiseco 82mm piston,bc rod,mugen 41,hondata s300.jz get 191wph 19torque only haiz...
Hi guys,
I have a friend who have a satria. He needs some help, his radiator always dispence water with yellowish/rust color. His mech asked him to weekly start his car and put a hose of running water to replace the dirty one. He have serviced his radiator around 6 months ago. Is there any solution for this. Solutions like radiator shampoo if it exist. Help will be very much appreciated. Thanks.
