3SGTE ST215 into ANE11
wishturbo
47
7
1,508
3SGTE Conversion Toyota Wish
Ouch! I'm mad once again, c'mon! this is family car man! Are u nuts!
Once upon a time...
Donor Vehicle: JDM 99 Caldina GT-T (ST215)
Mileage: 120,000
Displacement: 1998cc
Valve train: DOHC 4 Cylinder, 16 Valve, 2.0L TURBO
Horsepower: 191 kW (256 hp) @6200 rpm
Torque: 324 Nm (239 ft·lbf) @4400 rpm
Compression: 9.0:1
Bore/Stroke : 86mm
Day 1 - Disassemble
Day 2 - Cleaning
Engine cleaned
This Haltech will be the ECU
This turbine will boost my 3SGTE
Day 3 - Fitting
All 4 mounts fit and no need to adjust
Day 4 - Locked
Gearbox disassemble
Rear wheel axle case removed and sealed
AWD successfully locked
wishturbo
47
7
1,508
Nicely done! But can provide more on how they lock up into 2WD?
Hard metal placed in between of the gear. Click to enlarge.
On the top of the gear, weld with TIG. Click to enlarge.
AE75
278
11
place a hard metal in between the differential and Weld with TIG? I get some ideal already... thanks for useful guide
WrX7
266
3,018
Wishturbo, may i know how much u pay for the conversion and the JDM 99 Caldina GT-T (ST215) halfcut???
mind to tell?? thanks..
wishturbo
47
7
1,508
RM6k for halfcut, RM3-4k for installation
pcmoddingmy
1,147
101
www.pcmoddingmy.com
Fuh.... nice project... done in tire shop? Interesting!
wishturbo
47
7
1,508
Day 5 - Mount
Hehehe,, tyre shop with good workmanship. Transplant many engines without problem. There got one skillful mechanic previously working at motorsport shop :rofl:
Btw, this is just stock conversion. After that the car need to inspect at Puspakom. After that, 2 more weeks at RMD garage for fabrication, after market part installation and tuning process :banghead:
AE101-Wong
4,448
113
whoa...very nice conversion..
i saw 1 half cut same like urs selling quite cheap, got abit gatal to squeeze this to my AE101..
How many of you are die-hard fans of classic cars? It's probably safe to say that millions of people would love to own an antique car, if for no other reason than the status that comes with it. In reference to Paul Tan's report on The 46th Victorian Hot Rod Show held in Melbourne recently, the culture is booming in the city of Oz, and such pieces of gleaming metal are considered...
