Accord Euro-R CL7 maintenance..
bulet
979
7
Cheras
of coz la dah change bro.....my engine using 5 litre, i think ur car should 4 litre je kot. lot of engine oil can used la, me always used shell semisyn dulu...but changed to honda semisyn oil now. shell oil quite bising la......if other otais, they used motul etc....
oil filter lak i'm using h22a standard oil filter, u can use k20a oil filter also.....dc5 nye la kot. its ok if used standard oil filter...same performance if used any brand also. only can feel the difference if u used different size of oil filter. dulu had used momo oil filter, size quite small, can feel the different...but have to change in next service la coz it capacity small
tweftfom
48
if cl7r...no variant ...all same...different on the optional parts
but if cl7r and cl7 and cl9 have different on the lsd....details can ask bro bien, he is honda engineer...hehehhe
btw, bro tweftfom...u finding 1 ke?
jst got cl7r last year la bro...but im a lil bit confuse coz when i did my skimming on the front rotors..asked the foreman to check whether my cl7r got lsd or not? but the answer is no..his finding was base on how the front wheel should respond to the other front wheel for ex if u move the left wheel forward, the right wheel should also follow in the same direction...but i dont think this is the right method to test coz cl7r use helical or gear type lsd..anybody can comfirm this?
bro bien maybe can help me...tq
helmistaley
63
wah...theres 1 more cl7r gang...lai lai..hehe.but tweftfom why did u skim ur rotors in the first place?and did u change ur brake pad also?
me also wanna hear explanation about the lsd thing....
aja
4,696
35
5,148
All Honda tyre R comes with Helical LSD type. This helical or so call 'part-time' non full lock LASD is non-noticable LSD, as compared to normal non-type R honda LSD like B16A etc.
For B16A LSD, If u turn front right tyre, the other front Left will pusing also..since it's full time. As for Honda Type R, this scenario will not happened. The LSD will only activated, once your car positioning already in 'slipped' situation.
Try to use Motul FF LSD Type 2 gearbox oil. The LSD characteristics will be more noticable, during slipped time!
bulet
979
7
Cheras
sifu had voice out:adore:
tweftfom
48
thanx aja for ur valuable info..we really cannot rely all the time to the mechanic..they are not always right...my car will be in trouble if i let the mechanic change the transmission oil base on his finding...
helmistaley..when i was cruising at 170 km/h the steering starts to vibrates when braking...dats why la i skim the front rotors..the brake pad still ok so no need changes...now all ok...
so helmstaley hows ur ride?
Bump:
helmistaley
63
mine is ok bro tweftfom..now looking fwd to do basic air intake mod,plug cables etc.i'm planning to remove the air filter box resonator and use drop in filter...so sifus does it make any improvement or just worsen the performance?
bulet
979
7
Cheras
what is air filter resonator?the big big thing inside bonnet tu ke?if that, oredi buang heheh...weight around 1kg kot...
i use M's open pod with K&N filter....really good. the air sucking sound quite high compare with others open pod...especially when u press the pedal...
helmistaley
63
ya la bro...the one box that hiding down there behind the bumper.but i still wanna maintain the original filter box with drop in K&N,and then see how the result is...
btw bro bulet,from where do u get ur open pod system?and what is M's(mugen ke?:hmmmm:...hehe,sorry if silly question..)
bulet
979
7
Cheras
bought it in japan...that time price around 50,000 yen =RM2000
http://gruppemusa.us/
helmi...show la ur car pic...i'll show mine....
ha ah la...seems we all still didnt see each other yet, y dun we post our car pic. mana la tau jumpa tgh jalan...can honk2:driver:....suggestion onli..if dun wan ok la...
aja
4,696
35
5,148
Weight 1 kg kah?.
No wonder my car super slow wan..:biggrin:
Apr 26, 2009
2
hello
need ur help
i want clutch set for my accord cl7 euro r from where we can get this ?
and civic type.r 2002 model and integra type,r and euro.r clutch is same ?
bulet
979
7
Cheras
hello
need ur help
standard clutch set can get from LHS jalan ipoh......exedy clutch set at sunway kot..
Apr 26, 2009
2
civic type.r and euro.r clutch is same ?
and for exedy clutch can plz give me the exact add or ph no# or any other contact no#
Hi All,
After the Japanese eye surgery the previous time, I have been given the honour to perform yet another eye surgery + skin whitening on a Korean.
Patient this time is a Kia Optima 2.0 year 2004. Headlamps have been heavily oxidized and owner feels that it is no longer safe to drive at night with this headlamps. A new replacement would have cost a few thousand but lets say we did it at a fraction of the price.
Lets examine the condition of the lamps:
Oxidation from 7 years...
