Strengthen Engine Mounting or Engine Damper
dfx16
107
6
I had broke the engine mounting for the 3rd times within 2 yrs as i had FI an NA ride
A workshop suggested change new engine mounting and add on a engine damper
B workshop suggested strengthen the engine mounting via silicon
What's the Pro and Con?
Any suggestion?
Thks for any input
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
if done both and ur engine still vibrates alot at high rpm, its time to invest in full engine blueprint and balancing...
Bump: if done both and ur engine still vibrates alot at high rpm, its time to invest in full engine blueprint and balancing...
JINEIL2EN
Over 10,000 RPM!
15,317
525
Island Of Pearl
team99ers.2.forumer.com
at that time, the engine won't vbrate, but the whole car is....:proud:
JackWaiKit
262
5
www.friendster.com
I m using evo mounting for front & rear only,left & right use ori Mits...but vibrate during low rpm...
until my dashboard screw also loosen...
But i have also changed many time of Mits. mounting since it broken...
Nothing will cover the both...!!!:banghead:
popout
366
2
can i tumpang ask 1 question ?? wat is engine damper izzit like mounting?? cuz i see alot of engine damper like aerospeed... but duno wat is the function??
popout
366
2
So izzit every car come with this thing original or just an additional thing
Hi anyone every used or have any knowledge on the KYB RS PRO adjustable suspension set, planning on getting them for my 2009 proton satria neo, would like to be able to lower it at least 50-60mm are these capable that?
http://cloud.tapatalk.com/s/5862a6d7c931c/Screenshot_20161227-173650.png?
Sent from my SM-G935F using Tapatalk
