Strengthen Engine Mounting or Engine Damper
dfx16
107
6
I had broke the engine mounting for the 3rd times within 2 yrs as i had FI an NA ride
A workshop suggested change new engine mounting and add on a engine damper
B workshop suggested strengthen the engine mounting via silicon
What's the Pro and Con?
Any suggestion?
Thks for any input
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
if done both and ur engine still vibrates alot at high rpm, its time to invest in full engine blueprint and balancing...
Bump: if done both and ur engine still vibrates alot at high rpm, its time to invest in full engine blueprint and balancing...
JINEIL2EN
Over 10,000 RPM!
15,317
525
Island Of Pearl
team99ers.2.forumer.com
at that time, the engine won't vbrate, but the whole car is....:proud:
JackWaiKit
262
5
www.friendster.com
I m using evo mounting for front & rear only,left & right use ori Mits...but vibrate during low rpm...
until my dashboard screw also loosen...
But i have also changed many time of Mits. mounting since it broken...
Nothing will cover the both...!!!:banghead:
popout
366
2
can i tumpang ask 1 question ?? wat is engine damper izzit like mounting?? cuz i see alot of engine damper like aerospeed... but duno wat is the function??
popout
366
2
So izzit every car come with this thing original or just an additional thing
this morning, when i check my radiator, find out that the water look very rusty.. so i went to a workshop to FLUSH my radiator water and they refill brand new radiator water which is very good ones. one bottle 14dollars. i pour in 2 bottles. After changing, i drive for about 15 minutes, i realised my water temp shoot to MAXIMUM, i stop my car immediately and realised the water is LEAKING (very fast) from water pump area. i quickly TOW my car to my workshop again.
WHAT really happened? can...
